Question about Acer Aspire 5500 5570-4421 Laptop
No power laptop completely stopped working. No indication of any power. power supply is fine not sure about battery, couldn't test battery. any ideas???
  • 674 Answers
Check first the charger, if its working check the dc jact connector need to open you unit.. then check if the battery is not working when you remove it should be work even withtout the battery..
Posted on Sep 11, 2009
Testimonial: "it worked.thanks"
I have a toshiba qosmio laptop that stopped working all of a sudden. The problem is it will not start up. What I noticed is that that the power indicator lights on the front that are usually green are...
remove the battery and see if it works fine, use only the power supply. If it works the problem is the battery if not you need to test your power supply. That's the easier way
May 04, 2012 | Toshiba Qosmio F25-AV205 Notebook
No Power battery went dead I plug it in and still no power and it will not charge battery ether??
Your power inverter most likely has died or the connection between the inverter and the wall outlet cable has come loose. Most computer retailers sell universal power adapters you can test this with.
Mar 03, 2011 | Dell Latitude D510 Notebook
The laptop simply will not turn on. It was working fine last night when I shut it down. It has given to indication that there was any issues. I have plugged it in to another plug - in but even the...
Remove the battery and hold down the power button for 10 seconds. Try powering on without battery in.
Make sure all power connections are firmly connected.
Mar 01, 2011 | Acer Computers & Internet
My laptop hangs everytime i use the power supply (adp-75sb ab) provided for this unit (toshiba satellite a205-s6808) but when i start my laptop with the battery, everything works out fine. it only hangs...
Check the voltage output from the charger and see if it is within the range that is stamped on the charger body (eg: 20 volts) If it is below or above this, then the charger is faulty. If the green light is flashing on the charger, it means that power is "not being accepted" by the laptop and this indicates a faulty charging port / circuit.
Jan 18, 2011 | Toshiba Computers & Internet
Computer will not turn on
Try a different power outlet
check whether battery is completely drained out
check for a battery meter behind the battery which can indicate whether the battery is completely drained off or not
check whether the system ppowers up with the AC adaptor connected
check whether there is any lights lit on the system indicating some activity is happening
Dec 25, 2010 | HP Pavilion TX2000Z Notebook
My dell studio 1737 will not charge the battery; however it will run on either the battery or the power supply at leas until the battery dies completely. The power supply is working properly. I have tested...
If the power supply is powering the system without the battery installed, and the battery powers the system without the power supply attached, but the power supply will not charge the battery in the system...chances are very high the charging circuit on the systemboard is not functional. There are a few possibilities as to why but the only real solution would be to replace the systemboard since the charging circuit is integrated. You could run through the charging circuit to locate the exact fault but you will need schematics in order to resolve if you are comfortable with micro-soldering.
To verify, if you can, place the AC adapter and battery into another 1737 and see if you get charging on the battery.
May 22, 2010 | Dell Studio 1737 Laptop
No laptop power from mains or battery
just remove the RAM chip and try to power on
then clean the ram and re install it then check.
Oct 05, 2009 | Dell XPS M1330 Laptop
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
My compaq evo stopped working. For about two weeks I had a buzzing where I place the power cord. At that time periodically the whole thing would shut down. Also now it will not start at all and the...
Allen -
It sounds as though you may have either blown the power supply, or burned the power circuit on the motherboard. That buzzing sound usually indicates an electric arc, where electricity passes through open air from one contact to another; In this case, it was probably caused by a loose or broken solder connection on the laptop's power jack.
If you can get your hands on an identical or equivalent power supply, test it with your laptop. If it works, then the power supply just needs to be replaced.
If not, try taking the battery out of your laptop, and plugging it in again. Sometimes, when a power supply burns up, the battery will discharge, rendering it inoperable.
Hope this helps!
-thinstatic
Jun 13, 2008 | HP Compaq Evo Notebook N600c
Acer Aspire 5500 5570-4421 Laptop Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
