Question about Emerson Pool & Spa
Motor feels excessively hot after running for only 30 minutes- brand new emerson pool pump - doesn't start hard, make any noise or grind to a halt but the middle of the metal case is almost too hot to touch
  • 4 Answers
It's sounds normal the motor will get hot. If it were overheating it should automatically shut down wait to cool off and restart.
Posted on Sep 12, 2009
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson EB848 is leaking, running hot and tripping the circuit breaker
How old is the motor?
If new is it the same hp as the old one?
if no and it's a lower hp motor did you replace the impeller to match the decrease in hp?
if no..this is why it's running hot.
the leak is an easy fix. you need to replace the pump seal. there are four main seals used in pools and spas but I cant tell you the one you need with out knowing the brand of the wet end.
water + electricity will usually trip a braker......
Oct 05, 2013 | U.S. Motors Emerson EB848
Hayward power flo lx swimming pool pump is making a grinding noise
THAT IS A ABOVE GROUND PUMP AND THE BEARING ARE GOING BAD, ITS HARD TO FIND A SHOP THAT WILL WORK ON ONE OF THOSE PUMP-MOTOR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING AND HAVE HIM LOOK AT IT TO SEE IF IT'S A FIXER OR NOT ? .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 07, 2012 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
I have emerson 1081 pool pump, stop running the other day, motor just humms when turned on. replaced capacitor, still have same problem. motor turns freely by hand. what else could be the problem.
probably should pull it out and take it to a motor repair shop. sounds as if maybe the windings are bad.
double check the installation of the capacitor but doesn't sound like the motor is any good. they may be able to repair it though.
US Parts Center
Aug 21, 2011 | Emerson Keyed .5hp Fullrate 115/230v
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
I purchased a new 3/4hp Emerson pool pump installed it and the only thing it will do is hum.
OUT THE BACK SIDE OF THE MOTOR IS A SLOT IN THE SHAFT FOR A SCREWDRIVER , SEE IF YOU CAN TURN THE MOTOR OVER(BREAKER OFF !) YOU MAY HAVE BOUND THE IMPELLER OR IT COULD BE SET FOR 230 VOLTS AND YOU ARE RUNNING IT ON 115VOLT.....
IT MAY HAVE A BAD START CAP OR THE SWITCH MIGHT NEED CLEANING. THESE EMERSON MOTORS CAN BE HARD TO WORK ON DO TO THE HUGE AMOUNT OF PLASTIC PARTS
Jun 20, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Punp is runnin hot
motor has too much drag. hopefully something wrapped around shaft, worst case take motor to graingers and replace just motor
May 28, 2009 | Emerson Pool & Spa
Pool & Spa Logo
402 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
