Question about GE JVM1650 1000 Watts Microwave Oven
JVM1650SH02 keeps shorting out after a couple seconds
The time display flutters when running and then shorts out after a couple seconds of running. I opened it up and made sure all of the connections were good and it seems to have temporarily solved the problem. A service man said that the Mag Tube is bad and that it is covered under warrantee for 10 years but he would also replace the capacitor and diod when replacing the mag tube which would cost 150 bucks. Can I just replace the mag tube without also replacing the diod and capacitor?
  • GE Master
  • 9,098 Answers
Most of the time replacxing them all is done due to ignorance about how to actually test devices, a mistaken notion that it's somehow necessary, or to pad the bill.
The diode may be necessary in some cases (if it tests bad) but the capacitor is almost certainly not needed.
When a capacitor fails, it almost always shorts. If so, the fuse would blow when you peress "Start" to begin cooking.
I've rarely (if ever) seen one fail without shorting.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you're doing this yourself, G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Almost certainly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 11, 2009
Microwave keeps blowing fuses after u push start and runs 2-3 seconds
short in the circuit or magnetron take it in for a proper diagnosis but generally it is more expensive to repair than replace
Jul 16, 2017 | Microwave Ovens
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
We have a GE spacemaker microwave model jvm1650sh02 serial 3hh902209b. When it is turned on the display flickers and then the entire unit stops working 3-4 seconds in and the display shows all asterics...
Assuming there's no bad power connection along the line, then it may be a "noisy" magnetron.
See my detailed information page here:
http://www.microwavecontrol.com/mag_test.htm
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 06, 2017 | GE Microwave Ovens
Microwave appears to have no power. Display is blank. Checked and found internal fuze blown. Replace the fuze with 20A ceramic fuze. Display works. When try to cook something, microwave runs for about half...
You have a short somewhere. Possible causes, defective interlock switches for the door,shorted capacitor, shorted diode, defective triac. More than likely its one of these.
Oct 01, 2009 | GE Monogram ZE1660SA Microwave Oven
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave, runs only 2 seconds, then stops
The problem you describe on your JVM1650SH02 is a failing "noisy" magnetron which is emitting electrical interference that disrupts your microprocessor.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You will find a technical sheet hidden behind the grille or behind the controls. It's handy for locating parts and troubleshooting.
You can find an exploded view and parts list by entering your full model number from the tag here, and you can also order parts there.
On your model, you may need to remove the oven from the wall. The installation instructions here will be helpful.
Pro tip: In many GE models, dropping the floor plate that holds the high voltage transformer is necessary to get the magnetron in and out.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I AM VERY DISAPPOINTED IN GE 'S HELP WHERE THEY WANT TO CHARGE 9.99 DOLLARS FOR HELP ON MY MICROWAVE WHICH IS OUT OF WARRANTY. IT IS ALMOST 2 YEARS OLD
Hi AGAIN DIBARTRK
Now that you have indicated the make of your oven....... the fault codes for GE microwaves are as follows. I have given you all of them for you future reference. :)
F1 - ( open thermal sensor ), will occur below 190�F of cavity temperature within 15 minutes of starting convection, combination or roast cook.
F2 - ( shorted thermal sensor ), will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
Note: it will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted/open.
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
F4 ( open humidity sensor ), will occur if humidity sensor is detected as being open continuously over 5 seconds.
F5 - ( shorted humidity sensor ), will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Note: It will will take a minimum of 15 seconds after the magnetron is energized before the F4 or F5 code will be displayed if the humidity sensor is shorted/open. Also the unit must be plugged into a 120 volt outlet for at least 5 minutes before sensor is checked, this also applies after the humidity sensor has been changed. Before checking operation of new sensor allow init to be plugged in for at least 5 minutes.
F6 - ( shorted temperature probe ), will occur if temperature probe is detected as being open or not plugged into the receptacle. If probe is plugged in and "ProbE" is on display, check probe for continuity with ohm meter.
they are all different for different brands... It is much easier to get a solution from FixYa you actually tell us what sort of equipment you are having trouble with. :) Do I get a FixYa rating now... :)
regards
robotek
May 06, 2008 | Microwave Ovens
Crisp display
yes, it does indicates there is a bigger problem It has run a self- checking program and displayed the error before calling help see in this model page there is a manual of the oven, check last pages if they help u if no still there are instructions what to do and who to connect read it well before calling it will save u more then a couple of $$$ good luck windman
Jan 17, 2006 | KitchenAid KBMC140H Convection Microwave...
GE JVM1650 1000 Watts Microwave Oven Logo
361 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
