I do not have good news for you---this model is prone to the optical light engine going bad---usually a red oval area in the middle of the screen----I have also read that there are now several class action lawsuits related to this problem in this set. You can Google the model number and you will set what I am talking about.
I have replaced several light engines(called an optical engine) in this model--both the 50V500 and the 60V500 have this problem.
The last time I checked the optical engine wholesaled for about 600 dollars and is major labor to replace--I had someone else here ask me about this set---He was in Canada and the first time he called Hitachi he was told they were not aware of any problem--after posting here with me he called them back and someone admitted they knew about this but had been told not to say anything or admit any problem---thousands of these sets all have the same problem.
Clearly the set is not worth a 600 dollar part plus labor---considering the cost of new sets, but the only other option you have is to try to connect with one of the several class action lawsuits---I found them by typing the model number and lawsuit after it on Google.
I know I am not giving you good news but I know this set.
If this information has been helpful for you, please take a minute to give me a vote here--I do this here for free.
If you have any questions or need advice reply to this post here.
There are light engines for sale on eBay for around $400US. Our TV does not show any white - only greens and yellows where the white should be. I found the 50V500 manual online - can the engine be replaced D.I.Y. without soldering or special tools?
My TV works great except that after it has been on a while, the screen turns green (audio remains...
(More)
My TV works great except that after it has been on a while, the screen turns green (audio remains fine) -- what is the problem? Thanks!
i have had two projection large screen hitachis and have not had a problem with either one. i am...
(More)
I HAVE HAD TWO PROJECTION LARGE SCREEN HITACHIS AND HAVE NOT HAD A PROBLEM WITH EITHER ONE. I AM LOOKING TO UPGRADE TO A FLAT PANEL AND I HAVE NARROWED THE SEARCH BETWEEN THE NEW FLAT PANEL 50 INCH HITACHI AND THE NEW VIZIO OF SAME SIZE. COULD YOU TELL ME THE GOOD AND BAD OF EACH, TO HELP WITH THE DECISION. THANK YOU
The tv won't come on it gets power but no picture and on the indicator lights on the control panel...
(More)
The tv won't come on it gets power but no picture and on the indicator lights on the control panel only the lamp indicator comes on and just blinks. Did the lamp go out?
do I have to hook up ps3 to dvi input in back of tv to get best quality picture and audio? I have it...
(More)
do I have to hook up ps3 to dvi input in back of tv to get best quality picture and audio? I have it hooked on front panel of tv but picture still doesn't seem all it should be...
