Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
What is the difference between 8 and -9 - The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
  • The Learning... Master
  • 8,073 Answers
8-(-9)=8+9= 17.
Suppose you have a temperature of -9 degrees outside and 8 (in fact +8) degrees in you home. What is the difference of temperature between the inside and the outside.
Starting from the -9 deg mark, you move up the scale counting the number of degree marks until you reach +8 degrees.
Each time you see a degree mark you add one
-9 Does not count, it is the starting point.
-8 Count 1
-7 2
-6 3
-5 4
-4 5
-3 6
-2 7
-1 8
0 9
+1 10
+2 11
+8 17
Hope it helps.
Posted on Sep 15, 2009
What is the difference between different GPON board?
Board GPON Type Port Quantity Optical Module Maximum Split Ratio ONU based shaping H802GPBD 1G-GPON 8 SFP(Class B+ and Class C+) 1:128 No H805GPBD
H806GPBD 1G-GPON 8 SFP(Class B+ and Class C+) 1:128 Yes H802GPFDH805GPFD 1G-GPON 16 SFP(Class B+ and Class C+) 1:128 Yes H806GPBHH807GPBH 1G-GPON 8 SFP(Class B+ and Class C+) 1:128 Yes H802XGBC 10G-GPON 4 XFP 1:128 Yes Huawei GPBD Board Thunder link com
Nov 25, 2016 | Televison & Video
File size sharpening stihl 023C
There are six different chains with different pitches that can be used on this saw. 1/4, 3/8 PMN, and 3/8 P use a 5/32" file; 0.325 uses a 3/16" file; 3/8 uses a 13/64" file; and 0.404 chain uses a 7/32 file. The pitch is ususally stamped on the side of the chain teeth.
Sep 25, 2013 | Stihl Chain Saws, 017, 019, 021, 023 & 025
What's the difference between the H type and the 8 type collar?
The 8 type is made of two loops that go around the cat's neck and torso respectively, attached at the back of the neck. The H type harness connects the two loops with an additional piece, to which the leash connects.
Jul 18, 2012 | Cats
Comm error 442
From the HP website:
420 V.34 negotiations have failed from the originating machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 421 V.34 negotiations have failed from the originating machine during phase 3. Phase 3 occurs after V.8, before phase4, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 422 V.34 negotiations have failed from the answering machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged.
Solution:
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: 1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Jul 25, 2011 | HP LaserJet 3050 All-In-One Printer
What are the RPN keystrokes for the following problem: 8%+.9(12.2-5.2)+3%
The problem as written is not well-formed. The leading "8%" does not say "8% of what", and the "+3%" is ambiguous, so I assume the problem really is (( x + 8%) + .9 ( 12.2 - 5.2 )) + 3%, where x is a number entered before.
The resulting RPN key sequence is:
  1. x [ENTER] --- giving a value for the 8% to operate on
  2. 8 [%] [+] --- add the 8% to the previous value
  3. .9 [ENTER] --- push the 0.9 to the stack
  4. 12.2 [ENTER] 5.2 [-] --- evaluate the content of the brace
  5. [x] --- multiply .9
  6. [+] -- add the x + 8% and .9 ( 12.2 - 5.2 ) terms
  7. 3 [%] [+] --- add three percent to the result from step 6.
In case you actually meant ( x + 8% ) + ( .9 ( 12.2 - 5.2 ) + 3% ) - note the difference in the position of the braces:
  6. 3 [%] [+] --- add three percent to the result from step 5.
  7. [+] -- add the x + 8% and .9 ( 12.2 - 5.2 ) + 3% terms.
Note, the only difference is the reversed order of step 6 and 7.
Jan 19, 2011 | HP 12c Calculator
I have a 2.5 -8 Belvar 8A scope and I want to buy some flip up scope cover lens for it.But to order it they want exact sizes, I only have a tape measure and I came up with 1-6/8 for the eye peice and...
Dan, your best bet is to buy a set of calipers ($25) or find a friend with one, or take the scope to the shop where you expect to buy the lens covers and have them measure it for you. The butler creek covers come in a easily opened container and most shops will let you check fit in the shop. the 2.5 x 8 x ? does not really help you as the ? is the objective lens diameter. While this is good to know, different scope companies 40mm scopes may take different cover sizes as the tube outside diameter may be different.
Hope this helps
Sep 02, 2010 | Bausch and Lomb Optics
Master lock
The difference is 3/4 of a inch in lengh and 2 cm thicker. I would go with the 7-3/8, it bigger in lengh and thickness.
Dec 02, 2008 | Master Lock Bicycle Lock
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
215 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
