Question about Maytag M6D24E7A Air Conditioner
Where on the unit is the air filter?
Where on the air conditioner do i find the air filter? i have been trying to find it for a while. i want to change it and don't know where on the unit to find it. jean
  • 52 Answers
It is behind the vents the front should open so you can clean the filter
Posted on Sep 11, 2009
Air conditioning clean filter daikon 410a
Instruction manual is here, but the Model number you posted is for the outside unit, not the inside unit where the filter is. Front usually lifts up and you slide the filter out and wash it.
Nov 28, 2016 | Filter Heating & Cooling
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    My Air Conditioner started blowing hot air. Code p2181 came up. I have had problems with my fuse box over my battery. Could this be the problem again?
  • 2
    Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditiner
  • Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4
    Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor response to detecting room tempeture is needs replacement I say I'd loose business but rather clients trust me then go elsewhere recommend me for what you'll pay get a new one if it doesn't work
  • Sep 15, 2013 | Cars & Trucks
    My air conditioner keeps shutting off and on
    Hi Brittany - When was the last time the filter was clean? Restricted air flow from dirty air filter can caused air conditioner to turn on and off rapidly. Make sure there is nothing blocking the airflow to the unit like blinds, drapes, furniture, etc which could restrict air distribution. Outside condenser coil could possibly be blocked or dirty. Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc. Verify that the plug is not damaged and try resetting the unit. If any proves to be ineffective, contact a professional to move forward accurately.
    Oct 13, 2012 | Frigidaire FAC127S1A Air Conditioner
    Moldy smell frigidaire air conditioner window unit
    Clean the unit with bleach water and let try. Clean the filter and make sure there is no debris in the unit where you can reach and clean
    Aug 07, 2012 | Frigidaire FAC126P1 wall/window Air...
    I have a Ruud Split unit and the only number I can find on it is s9201a and I'm trying to find an air filter replacement. Can you help me. Thanks
    the air filter will be in the wall of your house around the thermostat or in the indoor unit at the very bottom of it
    Sep 24, 2010 | Ruud Central System Air Conditioner
    Bryant Legacy Air Conditioner doesn't blow out cold air
    Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
    May 27, 2009 | Bryant 462AJC021BA Air Conditioner
    Filter
    THE FILTER WILL BE IN THE INSIDE UNIT TO THE BOTTOM OF THE UNIT,UNLESS THEY INSTALLED A FILTER BACK GRILL
    Jan 16, 2008 | Weather King 10AJA6001AH Air Conditioner
    Air conditioner freezing up
    Your unit is low on freon. Take the unit to a service facility & have it recharged & the leak repaired. Note that ice formation may normal if the outside temperature is below 45-50F. If you must use it in the meantime, leaving the unit on fan only will melt the ice much faster.
    Jul 17, 2007 | Goldstar R5050 Air Conditioner
    Maytag M6D24E7A Air Conditioner Logo
    Top Maytag Heating & Cooling Experts
    Rick Johnson
    Rick Johnson
    Bill Long
    Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
