Question about Home
Jets shut off...
After about 25-30 minutes of running the jets they stop. I have to shut it off for a few minutes and then I can turn it back on but it goes off again after a few more minutes. What can I check or what may need replaced?
    Scholar:
  • 80 Answers
Most jetted tubs turn off after 20 to 30 minutes. It is a safety feature as well as a thermal protection feature for the motor. I doubt if there is anything wrong with your tub. If you contact the manufacture of the tub, they will most likey confirm what I have said to be what is going on. If it was a hot tub, like the ones used outdoors, this would signify a problem.
Posted on Sep 12, 2009
Aquaglass whirlpool tub
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Engine starts but stops after a minute or on a hill or slope
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 15, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Toro lawn mower shuts off after running 2 or 3 minutes
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 11, 2010 | Toro Lawnmower Lawn Mower High Wheel...
Lawn tractor runs fine then shuts off then runs fine then shuts o
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 23, 2010 | Sears Arnold Lawn Mower Replacement Eager...
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Engine stops running after about 10 seconds
run a few times like that and it will flush the gunk out of the jets, but most of the time you will need to rebuild the carburetor.
buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position.
Good Luck, I hope this helped
May 19, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a feather lite weed eater xt26 and it will
they were in/out.
Please rate me, Thanks
May 08, 2010 | Garden
Gas trimmer runs for a few seconds and then stops
they were in/out.
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Have a homelite grass trimmer crank ok run ok will trim grass for about 2 minutes then stop if you crank it and run for few seconds and the give it the gas it will not take gas just stop have replaced both...
they were in/out.
May 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Home Logo
134 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
