Question about Dual Car Audio & Video
I hav a 95 berrta and im tying to put a head unit
I hav a 95 berrta and im tying to put a head unit in without a converter and i need to know which wire goes to which and i need it desribed like which color to which.
  • chrisuftring Sep 13, 2009
    okay but its a dual head unit th wire colors are diff can u exsplan the colors and which to wire to ?
  • 655 Answers
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Posted on Sep 12, 2009
95 legacy the front end shakes sometimes if you pull over and start again its fine im thinking really bad tie rod?
could be bad tie rod bad tires bad ball joints tires not bal all would have to be checked most front end shops will check it all out for free, when you bring it in for a alignment or if you know how to check each on of these then check yourself if you need more help on how to check any of these come back and ask
Dec 05, 2013 | 1995 Subaru Legacy
Another conundrum
To check for yourself, get an Ohmmeter and see if the outers of the amplifiers RCAs are connected to the ground or each other. If so then it cannot take speaker signals directly.
I suspect the 'High Level' the manual speaks of are the 4volt auxilliary audio signals that can be found on some newer head units, not speaker signals.
Speaker level signals from a bridge amp CAN be used on grounded RCA inputs if the signal is first passed through a simple decoupler and attenuator.
Diagram to explain....
Nov 22, 2007 | Infinity 475A Car Audio Amplifier
I have a 2002 dodge grand caravan sport, I checked all fluids and everything is up to date. But I put it on drive it make a drumroll like sound and when put in reverse it makes the sound louder. I hav
It could be your torque converter gone bad.. it will have all symptoms you list.. bad grinding type sound and vibrations.. not going into gear.. the down side is that without taking it out and replacing it I don't really know a way to test it. 90% certain torque converter failure. Good luck though.
Dec 08, 2012 | Cars & Trucks
Hi I havs a 95 HZJ75 landcruiser with a 1 HZ motor . the engine started overheating I have replaced water pump ,radiator thermostate now i have oil in the radiator and engine overheats within 10 min...
i think you may have overheated this unit again and possibly have crack or cracks in the head around the precomb to exhaust valve area, and a few thou bend in head too. Question :- Do you have an after market turbo on this unit?
Nov 17, 2012 | 1995 Toyota Land Cruiser
My car makes a clunk sound sometimes when I drive.
without having vehicle up on a four poster and putting my head underneath ?? as for the rattle ?? this could be pinking caused by low octane fuel ,95 unleaded is what it should have
Apr 05, 2010 | 2006 Pontiac G6
Im having trouble installing my double din alpine deck in my 2008 f-150. At one point I had everything installed and ready to go, But when I went to open the face to put a cd in the the monitor had trouble...
According to Metra you are using the right dash kit you just need to figure out the alignment for the radio. It will take some time but you will get it. Try to pull the head unit forward on the mount kit for the clearance.
Sep 25, 2009 | Alpine Car Audio & Video
Hello i would like to add a din head unit a few 6/9s and maybe a sub if poss into my saab 9-3 vector sport 56 plate is it possible with my existing 7 factory fitted speakers so that when i come to sell my...
My suggestion is to go to your local audio shop and pickup a dash kit and wiring harness to hook up the din head unit. I actually wouldn't recommend putting in aftermarket speakers unless you don't plan on reselling or they are blown. You could hook a sub up by running your power wire to your amp like usual, hook your amp turn-on wire to an accessory wire and buy a "line level converter" you will tap into factory speaker wires with this and it will convert it to RCAs. You will only need to do this if you are using the factory head unit. Also, unless the aftermarket unit has features that you want that the factory one doesn't, I wouldn't bother with that either. Good luck. Let me know if you need any more help.
-Andrew Hawkins
Aug 28, 2008 | Car Audio & Video
I have a lanzar mxa232 there is a L & R low. I do not have that on my head unit. How do I tie them in?
You would need a Line Output Converter (LOC) to convert the speaker level of the head unit to preamp level.
The amp also has speaker level inputs but the LOC will probably produce better results.
Let me know if you have any other questions.
Aug 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
HElp
Yeah unless you have the correct digital protocol converter these units will not work together. Most companies that make these D.P.C.'s ie. soundgate, pie, axcess, only make them so a factory head unit can control an aftermarket changer, not the other way around.
Mar 07, 2008 | Car Audio & Video
Car Audio & Video Logo
146 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
