Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Which panel do I remove to access the lamp - Panasonic PT-50LC13 50" Rear Projection HDTV
  • tvtechlady May 11, 2010
    brand and model no. would be helpful.
  • 93 Answers
Remove the back panel and find fan. your lamp should be right there. be extremely careful as the bulb is fragile
Posted on Sep 11, 2009
How hard is it to replace the bulb on an HLR6156WX/XAA
Hello
To replace bulb of your Samsung TV; proceedigns are given here:
[1]. Unplug the television and allow it to cool off for at least 30 minutes. The lamps in televisions get very hot and can cause injury if handled too soon after turning off the televisions
[2.] Remove the four screws from the cover of the access panel on the back of the television and pull off the cover.
[3]. Loosen the lamp by removing the security screw from the handle of the lamp. Though the lamp bulb is visible in the middle of the access panel, the handle is to the left of the panel
[4]. Grip the handle of the lamp and pull the lamp out of the access panel. Dispose of the old lamp in a waste receptacle
]5]. Slide the replacement lamp into the television, making sure the tip of the lamp is facing the right side of the unit
[6]. Replace the security screw for the handle of the lamp and reattach the access panel cover with the four screws. The television will not turn on if the access panel cover is not on the television
OK
Mar 20, 2011 | Samsung HLP5685W 56" Rear Projection...
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
How do you remove the air filter box on a 2001
REMOVAL
Release hood latch and open hood.
Access Rubber Grommet
Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
Fastener Locations
Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
Remove Push In Fasteners
Remove the push pins attaching the fascia to the upper radiator closure panel.
Headlamp Jack screws
Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
Roll Fascia Forward
Roll fascia forward to clear way for headlamp housing removal.
Disconnect wire connector from back of lamp socket(s) and/or bulbs.
Remove Headlamp Housing
INSTALLATION
CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
Place headlamp housing into position.
Connect wire connector to lamp socket(s)
Verify headlamp and signal lamp operation.
Install jackscrews to attach headlamp housing to crossmember.
Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
Install nut on fascia stud through the splash shield access hole.
Verify headlamp operation and alignment
Nov 03, 2009 | 2001 Chrysler 300M
Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Need to replace right brake light. How do I remove and replace trunk lining to get access withou doing damage to the liner? What is the correct lamp?
Remove the luggage compartment rear trim panel. Detach luggage compartment side trim panel. Detach the rear lamp assembly bulb holder. Remove the rear lamp assembly. To install, reverse the removal procedure.
Aug 03, 2009 | 2003 Jaguar S-Type
Lamp burnt out; can I replace it? everything else still works ( carosel, clock etc.)
there are usually access panels to replace lamp, it may be inside oven or on outside case or you may need to remove cover to access lamp,be careful especially if you need to remove cover,even after its unplugged
Jul 20, 2009 | Panasonic Microwave Ovens
How do I change the rear license plate light bulbs?
License Plate Lights Removal & Installation License plate lamp retainer clips
To Remove:
Remove or disconnect the following:
  1. License plate
  2. Pin-type retainers and the luggage compartment lid trim panel
  3. License plate lamp electrical connector
  4. Lamp socket from the license plate lamp
  5. Using a suitable tool, through the access hole, release the clips and remove the license plate lamp
To Install:
  1. Install or connect the following:
  2. License plate lamp
  3. Lamp socket to the license plate lamp
  4. Electrical connector
  5. Luggage compartment lid trim panel
  6. License plate
Jun 06, 2009 | 2000 Lincoln LS
HOW TO REPLACE HEADLIGHTS ON 2000 CHRYSLER LHS
ATTN: NIKKICARROLL
here is how to replace the bulb in your vehicle
  1. Release the hood latch and open the hood.
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp.
  3. Remove the screws holding the headlamp module halves together.
  4. Separate the module halves.
  5. Disengage the wiring from the headlamp bulb.
  6. Remove the retaining ring from the back of the headlamp bulb.
  7. Pull the bulb from the lamp.
To install:
  1. Push the bulb into the lamp.
  2. Install the retaining ring to hold the bulb in the lamp.
  3. Engage the wire connector to the back of the headlamp bulb.
  4. Place the module into position on the vehicle.
  5. Install the screws to hold the module to the vehicle.
  6. Install the radiator closure panel sight shield.
  7. Check the headlamp alignment and operation.
88176gb1.gif Exploded view of the fog lamp with the bulb removed
Click to Enlarge
  2. Remove the radiator closure panel sight shield as needed to gain access to the headlamps.
  4. Separate the halves.
  5. Remove the fog lamp wire connector cover.
  6. Disconnect the wires from the fog lamp bulb.
  7. Disengage the retainer clip holding the bulb to the fog lamp.
  8. Remove the bulb from the fog lamp.
To install:
  1. Place the bulb into position in the fog lamp.
  2. Engage the retainer clip to hold the bulb to the fog lamp assembly.
  3. Attach the wire connectors to the fog lamp bulb.
  4. Install the fog lamp wires connector cover.
  5. Place the module halves together.
  6. Install the screws to hold the headlamp module halves together.
  7. Install the radiator closure panel sight shield.
  8. Verify the fog lamp operation and alignment
ATTN: WDSNEED1
Removal & Installation 88176g87.gif Remove the screws retaining the headlamp module to the mount adapter
Click to Enlarge
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp fasteners.
  3. Remove the screws holding the headlamp module to the mount adapter.
  4. Separate the headlamp module from the mount adapter.
  5. Disengage the wiring from the headlamp and foglamp.
  6. Remove the headlamp from the vehicle.
To install:
  1. Attach the wires to the headlamp and foglamp assembly.
  2. Place the headlamp module into position on the mount adapter.
  3. Install the screws to hold the headlamp module to the mount adapter.
  4. Install the radiator closure panel sight shield.
  5. Check the headlamp alignment and operation.
Jul 28, 2008 | 1994 Chrysler New Yorker
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
