Question about Lexmark X4270 All-In-One InkJet Printer
I am trying to scan a document with my Lexmark X4270 and I have it on scan and it says to scan to different options I choose MS word and it says press stat button to begin. I do not see a start button only a select button and then it starts the process over!
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I scan a document on Lexmark x4270?
Perhaps the Lexmark X4270 user's guide will be able to help you. You can view and print your printer's user guide from the Lexmark website for free. Click on this link Lexmark X4200 Series User's Guide. Scroll to Scanning for the steps on how to scan a document. Make sure the Lexmark OCR scan software is installed on your computer. I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark X4270 All-In-One InkJet Printer
I don't know how to scan and save the results to a file on my Lexmark. Can't find my user guide
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 6200 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Oct 18, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Scaanner bed, where does it go?
Please follow the steps given below to scan a document:
1. Go to "Start," "All Programs," Lexmark printer, "Lexmark All-in-One Center."
2. Click "Scan," "Send scanned image to".
6. Under "Display Advanced Scan Settings" you can see change settings, which will affect the outcome of your scan.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X4270: How to scan directly to PDF format
Does this model come with a "Lexmark All in One Center" software ?. If so, try this link and see if it helps:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=0&ccs=229:1:0:439:0:0&mode=DOCS&doctype=KB&term=pdf&docid=ENUS20322
If the "File" option does not work above, you can select the option "Send Scanned Image to" - 'Acrobat Reader'.
May 28, 2009 | Lexmark X4270 All-in-One Multifunction...
My Lexmark P4350 printer is not scanning images to my computer?
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
LEXMARK X4270 SCAN ONE PAGE NOT MULTI-PAGES
S:
Please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Also, let me know the error message while scanning the document.
Apr 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lemark X1270 Error: Image Transferring Buffer Overflow
your's tech expert
Jeeth
Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Scan to Microsoft Works document is SMALL... tried settings... nothing works
I've always been told with text recognition, etc. that the OCR is only as good as the spell checker and formatting capabilities of the application you import to. Works is unfortunately only a step up from using Wordpad and I believe this is probably an issue with MS Works not your printing software. Make sure you are in "Print View", but bottom line... you may need to scan to scan some documents to another application first and import the file after.
May 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 doesn't want to scan
sounds like your scan settings need a look..do you have the print manager installed?
May 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
