Where do i find the filter of a maytag room air conditioner? i have been looking to change or clean it. can't find it. please help. jean.
  • 615 Answers
Home depo gou unioversal one that you can use if not you can make one tell you find the original...just sheet from them for filter and cut it for size.
Posted on Sep 11, 2009
Where is the filter to clean on your air conditioner
Hello, typically the filters are located in the back of the unit.
Jul 15, 2012 | Maytag M6P09S2B Portable Air Conditioner
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
The aircon is on but is not cooling the room
Please follow these steps to get better cooling:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 21, 2011 | LG LS-L1210CL Mini Split Air Conditioner
On the "super" cool setting, it's not cooling the room too well. Is there a filter that needs to be changed?
There should be an air filter located behind the grill of the unit. This filter should be cleaned once every two weeks while the a/c is in use. Hope this helps
Jul 24, 2010 | Emerson Quiet Kool 10GV13 Air Conditioner
The air conditioner won't cool the room
not change, just check to make sure clean, you can run water over them to clean.
Jul 07, 2010 | Sharp CV-P10MX Air Conditioner
I need to clean behind the front panel of a Maytag B137FBF4 air conditioner and I can't find the manual.
The grill just has a couple of screws and spring clips. Once the grill is off pull the unit towards you, it should slide out far enough to access the back if the evaporator coil.. If it won;t slide out, look for another srew holding it to the frame. Make sure unit is unplugged. The back of the evaporator should be the clean side. The filter is oon the room side of the evaporator.
Oct 28, 2009 | Maytag M6Q10F2A Air Conditioner
Where on the unit is the air filter?
it is behind the vents the front should open so you can clean the filter
Sep 11, 2009 | Maytag M6D24E7A Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Blows room temperature air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Jul 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
May 09, 2008 | Maytag Chassis Built-In Air Conditioner...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
