Question about GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR DOOR HINGE BROKEN
GE MODEL# TFX25PRYF NEED TO KNOW WHERE TO GET THIS PART AND WHAT TOOLS I NEED TO FIX THIS WITH.
  • 60 Answers
When it comes to parts I always erfer to the manufacturers web site and then it will give you authorized repair places near yourhome.
http://www.geappliances.com/service_and_support/
http://www.myapstore.com/Omega/Dispatcher?REQUEST=STARTSHOPPING&zipcode=40225&couponCode=Promo+Code&username=P9900103&password=anonymous&origref=http://www.geappliances.com/service_and_support/&alias=http://www.geappliances.com/service_and_support/parts/
The last link will give their parts order area if you can get a parts number from the hinge.
Cheers
Al
Posted on Sep 11, 2009
Testimonial: "thank you for the info. very helpful"
My side by side refrigerator door swings open (somewhat out of control). It appears that the door stop is no longer working How can I fix this?
There is a self closer stop mechanism under the door between the door and the hinge, The door must be removed by removing the top hinge and lifting off the lower hinge flip the door and you will see a plastic piece which is probably broken there is also a piece on the hinge . Both should be replaced
Feb 27, 2011 | GE Refrigerators
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Same problem but part is not on schematics for my model.
that is what helps your door close..if the cams are broken the door will drop down and may drag..if that is your situation then yes, get that kit.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Doors need adjustment
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Mar 14, 2009 | GE GSH25JFR Side by Side Refrigerator
Door hinge on refrig door
the door stop on the bottom of your door is either bent or broken off. this si located on the hinge side on the bottom of the door the part number needed to repair it is WR02X11465 you will have to empty and remove the door from the refrig to replace the part. it is a fairly easy do it yourself fix. good luck and thanks for using FixYa Peyton
Feb 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Broken door hinge
Its not hard at all,Just losen all the bolts an the door would well, fall of :)
Just check if the fridge dit not get hurt or the door,other wize go for it....
Good luck.
Sep 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE REFRIGERATOR PFS22SBSBSS SHUTTING DOWN
I too have had the top plastic latch break. A extremely poor design incorporating a hinge on a fixed point screw. We had it fixed under the extended service contract. Prior to the repair person arriving, two, not one, full sets of door gaskets and hinge assemblies were shipped to us. The repair person broke one due to his mis-use of tools. The top latch can only be replaced with the entire door gasket assembly, and he installed both in 15 min. Now the freezer handle is falling off. We installed a GE Profile Stainless kitchen in 2006 and all the units have failed. My wife literally cries over the cost for such poor design and manufacturing.
Dec 31, 2007 | Refrigerators
GE refrigerator door problem (model TBX25PAYARWW)
Is sounds like you will have a broken or worn out or bent hinge. It may be a combination of the 3.
Dec 26, 2007 | GE Americana 15.6 Cu. Ft. Top-Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
150 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
