Question about Honeywell Programmable Thermostat Heater
AC PROBLEM my a/c runs continuously with only short pauses.
  • 615 Answers
The thermostates are out or it is too dirty and need cleaqning clean the filters first and then the condencing unit and then check the thermostat and make sure it is not set too low
Posted on Sep 11, 2009
My 2000 Yamaha Grizzly 600 runs for 5mins. and dies. Engine won't turn over for short period and then starts. This cycle continues.
fuel flow to the carb is slow. fills the bowl, runs till its dry. pause while it refills slowly, repeat.
Feb 21, 2017 | ATVs
Does anyone know what a two beep error code means on a shoprider scooter? It runs for a short distance and then cuts out.
Hi Sara ,what is the bleep code , bleep then a pause then bleep , how many bleeps before a pause? or is it continuous ?
Regards
Rob
Feb 04, 2016 | Shoprider Health & Beauty
Strange Noise While engine is running
do you have ac in your car let me know
Jan 04, 2014 | 2008 Toyota Prius
I have short in my 24v power line in my carrier ac/furnace
Hello, usually visuall inspection is the first thing I would do, may times the wires will short at the outside condensing unit or at the indoor control board. If you cannot see it visually then run a continuity test on the wires with a multimeter. To fix a short sometimes it is easiest to just run new wire.
May 04, 2012 | Carrier Heating & Cooling
Won't start...3 short beeps, pause and continuous repeat
This is a hardware warning, Usually memory modules the way to test that is take one of them out at a time if the beeping stops that is the one that is bad you can do this for all of your hardware parts inside. even DVD or CD burners just remove the power from each one of the hardware suspects. Upon doing this you will find the part that has malfunctioned you will need to replace it. John
Apr 09, 2012 | Computers & Internet
Engine stops while driving,will not start or stay running for hours,only to die again in short time replaced fuiel pump pcv valve,fuel filter
Do not replace any further components until you have your On-board diagnostic (OBD2) codes read.
Your vehicle is fitted with a sophisticated OBD computer which monitors the performance of all engine emmission sensors and components.
By jumping pins 5 & 6 of your datalink connector (DLC connector located under dash, above driver's knee), your Engine Check light will flash the codes present stored in memory.
  1. Run the engine until it reaches operating temperature, then turn engine OFF.
  2. Using a thin jumper wire (speaker wire will do), join pins 5 & 6 (note this connector may be upside down).
  3. Turn ignition key to ON (do not run engine) - the Engine Check light should start flashing.
  4. The 1st group of flashes is the 1st digit of the code; (short pause), 2nd group of flashes is the 2nd digit of the code (short pause) and so on. Note: codes will be separated by a long pause. E.g. Flash, Flash, Flash (short pause), Flash, Flash (short pause); Flash, Flash, Flash denotes: Code 323 etc
  5. Codes will usually repeat - turn key to OFF, once codes have been correctly read.
If the above procedure works for you, please post your codes on here and one of us will assist you with further diagnosis.
Cheers,
Aug 27, 2011 | 1997 Chevrolet Camaro
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
2006 MAGNUM REAR A/C NOT GETTING COOL
Hello, the problem with your rear a/c not getting cool is that the A/C is short of freon and your AC may need re- filling,and if you continue to running your AC,it can cause damage to the AC compressor, the re- filling needs to be done by qualified personnel.
Thanks
Aug 17, 2010 | 2006 Dodge Magnum
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Heating & Cooling Logo
156 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
