Question about Sharp AR-160 Copier
SHARP AR-160 IS BLINKING H 2 WHAT IS THIS - Sharp AR-160 Copier
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error H2-0 means Fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor please change the thermistor of heater unit, and also check the thermal fuse. This error also occurs when the upper heater thermistor is open or the fusing unit is not installed when the door is closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 11, 2009
Testimonial: "this was very helpful"
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
The SHARP AR-5320e is blinking H and then 4 I changed the toner but it keeps doing the same thing.
H4 trouble can be cancelled. press #-interrupt-C-interrupt simultaneously. after that machine panel will black-out hence you can STILL input 14 (in numerical buttons). press start/copy button. Yala--ur machine will initialize again. hope it helps
Feb 12, 2011 | Sharp AR-5320 Black and White Copier
Blinking U Blinking 2 in Display
When you press the copy key , it should show 40 and this is the solution. Remove the TD cartridge and unscrew the toner sensor and wipe with a small blower. Clean with a brush if the toner particle is stubborn and blow. Then screw back and clear with key press #*C* and enter16 then press copy key. If it re-appears, replace TD cartridge with Sharp AR-202ft. Enjoy the job.
Jan 07, 2011 | Sharp AR-M205 Copier
Sharp AR M-205 Blinking U 2
E prom error
Hold down the START button and retrieve the SUB-CODE,
EXample 04 or 11 or 12 or 40 ,
To clear:
Press #(button) interrupt(button) C(button) interrupt(button) within 5 secs.. then press one six (16) start (key)
Jul 10, 2010 | Sharp AR-M205 Copier
2 H blinking Sharp AR 164
H means HEAT, you have a defective FUSER
Apr 05, 2010 | Sharp AR-164 Copier
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-160 Copier Logo
245 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
