Question about Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Camera won't turn on
Brand new camera-charged battery for first time, fully charged. Tried battery in several direction- but followed arrows, etc Contacts are clean. No power.
    Brigadier General:
  • 11,967 Answers
Brand new?...take it back.
Posted on Sep 16, 2009
Won turn fully charged battery
How long you have the battery? I suggest you to fully discharged the battery and then charge it as much as you can, do this circle for several times. Hope this can help
Jul 23, 2013 | Fuji FinePix A330 Digital Camera
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
One day camera just stopped turning on.
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Mar 02, 2009 | Casio Exilim EXZ1050 Digital Camera
Camera
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Kodak easyshare z730
May 19, 2008 | Cameras
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Agfa FUJIFILM FINEPIX Z33WP Digital Camera Logo
154 people viewed this question
Top Agfa Cameras Experts
Larry Stiles
Larry Stiles
Tony
Are you an Agfa Camera Expert? Answer questions, earn points and help others
