the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Can you take a picture of that? I'd love to see it. email is [email protected]
