Question about Dell 948 All-In-One InkJet Printer
Dell 948 Printer Scanner/Copier 'clicking' on start up
Goes for about 60 seconds and ends with "Unrecoverable Scanner Error"
Happens whether it's attached to desktop or laptop.
Downloaded most current drivers.
Checked and reseated copier/scanner cables.
SUPER pissed. This problem came out of nowhere.
Dell 948 All in one printer Connection error
Try going to the dell website and doing the automatic driver instilation/ auto installer. This may help.
Jan 24, 2012 | Dell 948 All-In-One InkJet Printer
My Dell 948 printer produces a thick black line on documents
Leave the cover up and run a 'copy.' Look closely at the fluorescent scanner light and note if it seems equally bright from end to end.
If it does, the photo-assembly that acts as an image receiver is probably sick.
If it is, with the labor cost and potential non-availability of parts, you might be better off replacing it unless still under warranty.
Jul 02, 2010 | Dell 948 All-In-One InkJet Printer
Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Jan 17, 2010 | Dell 948 All-In-One InkJet Printer
Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
My printer/scanner/fax machine needs to be reinstalled
i have an hp not a dell but my printer does kinda the same thing
i tried re installing the the driver software and it worked ok
Jan 06, 2009 | Dell 948 All-In-One InkJet Printer
Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
Nov 14, 2008 | Dell 948 All-In-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
237 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
