Question about Lexmark T640, T642, T644 500-Sheet Duplex Printer
It keeps wanting manual feed paper instead of
Lexmark t642
It keeps wanting manual feed paper instead of taking paper from tray 1. How do you reset it
  • 60 Answers
There is usually no reset from the machine it is in your printer properties. Open the properties and set it to the tray you want it to feed from and usually there is a apply button try that.
Cheers
Al
Posted on Sep 11, 2009
Lexmark E232, keeps telling me paper tray is empty even though it has paper in the tray, then it just keeps clicking instead of picking up the paper and feeding into the printer? Please help
Go the Lexmark website and search on support for their telephone number. I've always had a experience with their support team even if the printer is out of warranty.
Apr 05, 2012 | Lexmark E232 Laser Printer
I am getting dirty copies. How do I clean rollers?
Here's an article in the Lexmark website on How to Check the Paper Tray Feed Rollers on a Lexmark T640, T642, or T644 Printer. Just click on this link: http://bit.ly/b71goj. Follow the instructions carefully. Hope this helps.
Jun 24, 2010 | Lexmark T644 Laser Printer
Lexmark T642 - I have plain white paper in tray 1 and yellow plain paper in the mp feeder tray. When I choose to print to the mp feeder tray the printer beeps to be loaded with paper but the paper is...
Make sure you have selected the multi purpose feeder (front of the printer) in the driver, not the Manual Feeder.
The manual feeder will prompt for paper on each page. All you have to do is to press the "Go" button.
Jun 03, 2009 | Lexmark T642 Laser Printer
T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Apr 29, 2009 | Lexmark T642 Laser Printer
Im getting plain paper jam at the fuser... I work for a large Hospital , and at this locations we have about about 100 pirnters they all are lexmark T642 and 50% of them have 3 to 4 tray and labels and...
You can replace those rollers. They wear smooth very quickly. In a pinch you can also peel them off the hub and put them on inside out. It will give it traction. It sounds like you already know about the little sensor in the trays themselves. I've seen them pop out of position and cause those probs. I don't think they could have made those sensors any cheaper if they had tried!
Apr 08, 2009 | Lexmark T642 Laser Printer
Urgent! MP Feeder problem - please help!
If your application is requiring the printer to select the manual paper feeder, you will get this problem. This feature is selected different ways in different application programs and different operating systems, but usually, after you select print, there will be a popup that allows you select the number of copies, portrait or landscape mode, etc. Either here, or in a secondary popup you reach by Print Properties or Advanced or some such button, there should be a paper source selection. Select Tray 1 instead of Manual Feed.
There is also a paper source selection available from the front panel. TO select Tray 1 instead of the manual paper feed:
Menu> - Select (Paper) - Select (Paper Source)
Use the Menu> key to select Tray 1
Select - Return - Return
Sometimes, for no apparent reason, my T614 loses its mind and wants to use the manual paper feed. I turn off the printer and turn it back on again to reset it... just like Windows! I could probably use the front panel to reset the printer, but it's easier to cycle the power.
I'm betting that answering your urgent question two months later didn't help you get your very important work completed on time. I hope you are still employed.
Mar 27, 2009 | Lexmark Optra T614 Laser Printer
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Mar 11, 2009 | Lexmark T642 Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Printer problem
Check your paper configuration. Make sure Tray 1 is configured for Plain paper and is showing the right paper size. If it is configured for anything other than Plain Paper, most of your jobs will not print. Also, if the size says something like Univseral, then the printer is not touch that tray unless your print job also specifies Univeral as the size. If is does say Universal, check the paper guide in the tray and make sure it is pointing exactly at the paper size you are using
Dec 12, 2008 | Lexmark T642 Laser Printer
421 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
