Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
Pioneer plazma model #pro-607pu set came in with no audio replaced output ic set came on for a sec and went off red and blue leds are on constant but no action from buttons or remote please help msul173@aol.com
SOURCE: pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Posted on Jan 01, 2008
  • 479 Answers
SOURCE: no picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Posted on Dec 10, 2008
electronick
  • 505 Answers
SOURCE: pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Posted on Jan 09, 2009
  • 8457 Answers
SOURCE: Pioneer Elite Pro-111HD 50
Ur video ic inverter board is dead.
U need a new video board.
Posted on Aug 23, 2009
SOURCE: As of the last 30 days or so the pioneer pdp 5070
I had the same thing happen...come to find out, the main board and power supply on these units seem to fail quite frequently...that's about a $1200 bill to repair!....mine's in the garage behind some shelfs...I purchased a new Samsung LCD after Pioneer wouldn't help, despite being only 2 months out of warranty...glad they're getting out of the plasma business so they can't "stiff" any more folks....
Posted on Dec 03, 2009
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
My tv model 60P8341A philips television screen is red and dull in color what do i need to do?
Hello
If your TV screen looks more red its red video output section is in trouble. Some philips circuts uses transistors while others uses ICs in that section. Philips magnavox model have both types. We here in India, have transistorised video output stages in Philips Magnavox sets. Whatever the ciruit type may be, the fault and its remedy is same.
Check whether your set has transistors or ICs used. If transistors are used, check the collector voltage at red video output transistor. If ICs are used, some sets uses a single IC for Red, Green and Blue output stages. Some of them have three ICs on board as Red,Green and blue output stages.
The video output stages are integrated on the base card of your TV. That is, a small square or rectangular board, pluged into the neck of the picture tube. You just find out the red,green and blue output transistors, or ics whichever may be used. It is ver easy to understand the video output transistors. They may be a little larger than other transistors.
An easy way is to locate the Red,Green and blue cathodes of the picture tube base board points. Check the voltage of the three of them They must be almost equal to each other, provided a little, that is, 2 or 3VDC difference is allowable and will be. In your case, the voltage at the red cathode may be , not may be, must be low. As cathode voltage lowers, emmision of that cathode will rise, and poise that colour is in excess. If the Red Cathode voltage in your TV is found low, say difference betwwen other two cathodes is 50v or so, repace the red output transistor or the Ic if used at that stage. If a single Ic is used in your TV as R_G_B outputs, replce the same. If three Ics are there, replace the red output control Ic. ok
If you have any more problems, inform fixya. They will send me alerts.
Thank you
Oct 20, 2010 | Philips Magnavox 27MS343S 27" TV
Aug 23, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Wire diagram pioneer deh-p7200
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
Mar 07, 2009 | Pioneer DEH-P7200 CD Player
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Pioneer elite 50 plazma tv
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
www.imageperfection.com
Jan 11, 2008 | Pioneer PRO-1009W 57" Rear Projection...
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
365 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
