Question about Goodman CLQ36AR49 Air Conditioner
Compressor tries to turn on but takes a while
Compressor takes a few tries to turn on
  • archergsx86 Oct 09, 2009
    tested the run cap and it was bad. Changed the cap and threw in a hard start and now it runs like a champ. thanks guys. sometimes i need reassurment
    Sergeant:
    Champion:
  • 232 Answers
You either hve a weak run capacitor or yoou have a Thermal expansion valve on the indoor coil and your compressor requires a Kickstart or hard start device .
Posted on Sep 14, 2009
  • 615 Answers
Weak comperessor you need to test it first...or you may have something that jaming the fan
Posted on Sep 11, 2009
I touched the cooling and 24 volt at the thermostat and the compressor fired right up but when in the regular cooling cycle the condenser fan will run but the compressor will hum every few mins like it is trying to start (delay im guessing). it takes about 15 to 20 min before the compressor will turn on.
Posted on Sep 12, 2009
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Power washer its spraying but no pressure
Sounds like a problem with the compressor. Can you hear it kick in or turn on when you turn the power washer on? Try turning it on and off a few times to see if you can hear it kick in? If the compressor is not turning on then there will be no pressure and the water will just basically flow through the system. Repairing a compressor is not something I can do via email without seeing the machine in person. I would suggest taking it to a repair tech for further evaluation.
Aug 17, 2011 | Garden
2005 pathfinder, ac has stopped blowing cold, and it shudders violently when the compressor tries to come on. Not sure where the problem is in the system, but it will blow cold for a few seconds, but then...
Hi and welcome to FixYa, I am Kelly. The symptom your describing sounds like the actual compressor pump take a lot of horsepower to turn it. Use a ratchet and socket on the center mounting nut for the compressor clutch. I would just about bet that it is VERY hard to turn. It should turn through with minimal resistance. If it is VERY hard to turn the compressor has failed. I would like to know either way on how hard or easy the compressor clutch mounting bolt turned. Just make sure you rotate the pump in the direction it would be turned while the engine is running.
Kelly
Jul 26, 2011 | 2005 Nissan Pathfinder
Compressor does not turn on
Replace http://www.appliancepartspros.com/part_details.aspx?part_id=3961332
Jan 08, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge/freezer doesn't work although light on
Hi David and welcfome to FixYa. I am Kelly There are a few things to try before you go replacing parts.
1. after the unit has sat with no power for about 30 minutes plug the unit in and listen for an attempted sart on the compressor. An attempted start will only last for approximately 40 seconds. During that attempted start listen to see if you actually hear the compressor turning. If you hear it turning and it again shuts off wait another 30 minutes and try it again. (On a unit that has been in storage for more than 6 months it can take a few attempts to get it going.) If it just hums and does not move then your compressor is locked and as it attempts to start you will notice a slight dimming of the house lights. Don't give up on it right away... do about 4 cycles of the plug it in.. listen for the 40 seconds then the CLICK of the compressor thermal overload switch. If your not hearing a CLICK after 40 seconds or so then there can be a compressor PTC relay / thermal overload (KliXon) problem or the possibility that the run capacitor has failed. After all of these have been checked out then you start looking at controls and power. Give it a few more tries to see if it takes off. If it does not then just repsond here and someone will help you.
Thanks for using FixYa,
Kelly
Apr 10, 2010 | Liebherr KDPes 3142 Premium
My Coby tv's VIDEO turns off after a few minutes
Ur backlight IC inverter board is dead.Tries disconnectors & reconnectors the connections to the board see if it work?
Sep 03, 2009 | Coby TFTV1923 19 in. LCD TV
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
125PSI 3 Gal 1 HP ceased up I think.
try plugging it in to a diferent outlet, and plug it directley in witthout using any exstension cords. It sounds to me that it may be pulling more amps than the outlet can handle.
Mar 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
213 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
