Question about New World G90m Gas Double Oven
Switch oven on and it fails to light and goes off again
Light comes on for 5 seconds and noise as well for 5 seconds and then it fails to light and the noise and light go off.
Gas man told us that the timer was not linked with oven and this was solved by correcting the clock
Posted on Oct 21, 2009
SOURCE:
Ignition Switch ?
There is a safety device built into gas outlets to prevent the gas from running if it fails to ignite. It works by heat. If a valve is not heated enough then the main valve will not remain open. That's why many gas appliances ask you to leave a second valve open for as much as 30 seconds after igniting. These valves are highly reliable. It sounds like your appliance may not be warm enough. Try to run it on high for 5-10 seconds before you turn it down. To access the valves; pull all the knobs straight off first then try to remove the facing by the screws. A make & model would be helpful since there are many different configurations.
Jun 27, 2015 | Ovens
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
My grill doesnt seem to be working,the oven seems to be ok making all the noise and stuff but the grills just not playing ball! nany help would be appreciated!
More than likely the grill element has failed, if the element light comes on, then I would go for the element.
If no light, then probably the grill switch is faulty.
Nov 14, 2010 | Zanussi ZBF360 Electric Single Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My cooktop is locked and I don't know how to unlock it. I did a self clean last night and the oven works fine.
Push in on the oven light switch and hold in for about 5 seconds cook toplight switch will go out same to lock it again.
Jan 24, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
New World G90m Gas Double Oven Logo
299 people viewed this question
Top New World Ovens Experts
Paul Carew
Marvin
Marvin
Steve Allison
Steve Allison
Are you a New World Oven Expert? Answer questions, earn points and help others
