Question about HP Photosmart 8250 InkJet Printer
SAME PROBLEM! Paper size not correct printing from word 2007 & word 2000!!! to an hp 6310- I KNOW THIS IS A PRINTER ISSUE- tried it on both VISTA & XP machines works mysteriously sometimes & then does not- also prints wrong pages!
  • 615 Answers
Check the setup on the printer before you click print go to the options and make sure it is set for the US and not selecting A4
Posted on Sep 11, 2009
6310 problems
You have not really provided enough information to properly answer your query. However, a couple of things to check. Did you set the right page size when printing? Was the size of the item being printed able to fit on the paper size chosen? Finally, did you ensure the page format was correct - eg: as in a landscape shaped original on to perhaps a portrait shaped paper?
Jul 27, 2014 | HP Officejet 6310 All-In-One InkJet...
I am trying to print envelopes (using MS Word mail merge) and printer says "paper mismatch"
first change the page layout setting in the document to envelop size then try to print ..... go to page layout size option the change the paper size to envelop then try to print ......
Dec 14, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to check cartridge ink level on new computer.
i think the problem is on that software.pls check the software cd or DVd. if it is fully compatible with windows vista.
Jun 13, 2009 | HP OfficeJet 6310 All-in-One Printer...
Trying to print name tags with avery 74520 on my hp 6310 and get rejected because of incorrect paper size...what do i set it for?
If your using Windows system you need to go the control and then select printers icon in the control panel and right click on and select printing preferences and change the paper type or use the control on the printer to change the paper type...
Good luck...
Apr 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing invitations
if you are printing from word 2010 and have an HP printer;
-set up your document on your screen how you want it to look, go into your print preview section, your printer should be listed towards the top of your page and directly under it should be "printer properties" click here, select the features tab in the next window and change your paper size to the correct size for your document.
-you may also need to go into the page layout tab in the main screen, select the size button, click on "more paper sizes" at the bottom of the window, select the paper tab and change the size of your paper again to the size of your document
-lastly, while in the "paper" tab window select "print options" towards the bottom right corner, left side of new screen click on advanced, scroll down to print and make sure there is NOT a check in the box that says "scale content for A4 or 8.5 x 11" paper sizes
Jan 22, 2009 | HP Officejet 6310 All-In-One InkJet...
I have an HP 6310 all in one. I am trying to send a fax, when I hit teh number 7, a star 41 appears after the 7, I think have to hit cancel and a color report prints
Error *41 is a wrong paper size or type error. Make sure that you have chosen the correct paper size and type in the printer configuration. Easiest way to get there is through any application going FILE > PRINT > Configure.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6310 officejet
Check the paper size setting when you set up the printer. Check page setup in File menu and specify the page size.
Dec 01, 2008 | HP Officejet 6310 All-In-One InkJet...
Envelops won't print
try to check the sixe of your envelope..check on the properties if the size that you did selected is the correct size of paper the you wanted to print.try to unplug the powercable of your printer and do not press the power button just unplug it immediately.press the power button for 5 secs. and insert the power cable..try to print
send me feedback for further troubleshooting,.,.,.
Aug 07, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart 8250 InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
