Question about Garden
Lawn mower will start, but won't move????
The mower will start, however, it won't go in gear or move? HELP!! I have put so much into this mower???
  • bargainbin2
    bargainbin2 May 11, 2010
    I need to know the type of mower and automatic or stright shift trans.
  • fkhattak11 Aug 01, 2013
    it IS SNAPPER REAR ENGINE MODLE 3312513BE WITH FRICTION WHEEL.
  • 389 Answers
If you have had either of the rear wheels off, remove the cover from the center and observe the shaft with the engine running and transmission in gear. If the shaft is turning, you have lost the 1/4 inch key that locks the axle to the wheel to make it go
Posted on Sep 15, 2009
Testimonial: "thanx...i will try this "
3 Suggested Answers
SOURCE: POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Posted on Aug 10, 2009
mowerman1857
  • 389 Answers
SOURCE: When I put the mower in gear, or engage the
Sounds like the seat safety switch is shorted or worn out. You can test it with a short length (about 6") of wire. Strip about a half inch from each end of the wire, unplug the connector under the seat and plug your "jumper" wire in to each side of the connector (NOT the seat switch) If it now works, replace the seat switch
Posted on Sep 16, 2009
Testimonial: "Thanks. The problem was the seat safety switch was loose and not fully engaged. When I plugged it in correctly, everything worked!!! Thanks again."
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Mar 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
555 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
