Question about Microsoft Xbox 360 Console
X box 360 e 74 error - Microsoft Xbox 360 Console
  • 313 Answers
E74 is a problem with the heat sync.
They now classify the e74 almost as bad as the RroD.
Just go to the microsoft 360 website and fill out a service request form and register your box if you haven't done so already.
Then where it asks you what your problem is, select the e 74 problem and the total cost should be $0.00 regardless of warranty. The RRoD and E74 are covered under the 3 year extended warranty.. the HDMI Elite models are all < 3 years old (it was released April 2007) so you are covered for sure.. They won't charge you anything
You can save time by packaging your own 360 and printing out a label they provide or you can request the packaging material which will take a little longer.
I hope this helps you. Let me know...
Posted on Sep 11, 2009
  • 6,784 Answers
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
  • Michael Masters
    Michael Masters Sep 11, 2009
    Contact Microsoft for a repair ticket if the AV replacement cable dose not produce positive results. the scaler chip will need to be replaced.
How to solve the err 071 of SC 810 control box of Juki
Hi Mohamed
regarding Error E 071 of SC-810 control please check :
1- thread trimmer cam correct adjusted or not.
2- there is a lot of thread into motor pulley or machine pulley.
3- if error E 071 coming immediately when turn power ON means problem inside control box, to confirm that please put working control box on machine , if error remove means problem at control box.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Mar 02, 2015 | Juki Sewing Machines
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Error code & solution
HI there
can you please inform us what's model of control box? there is no error named E815 !!!! please we need more explain to help you.
thanks and best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 02, 2014 | Juki DDL-8700
Set-top box has encountered an error BE1
If you use a cable box, then either the cable box is putting out a signal that the set cannot understand or the set has a problem with one of the boards in it.
Nov 18, 2013 | Samsung Audio Players & Recorders
I have an acer aspire laptop vista 5715z it takes ages to load the desk top page and then says , check acer net services, what does that mean
Does the internet work on the laptop? What style of error box is it? A windows error box or a different app box, like an Acer application error box?
Sep 18, 2013 | Computers & Internet
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
Error 110 primary pairing error
Call your provider for the box
Nov 03, 2012 | Televison & Video
Temprory problem - error code 2
fix my verizonyahoo mail
Apr 29, 2010 | Yahoo Mail
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
