My c5280 constantly tells me it is out of paper, even when I turn on/off, replace paper, try to run single sheets, etc...any ideas?
    Sniper:
  • 54 Answers
1. open hp solution center
2. in paper settings change paper type as plain paper and try it should resolve.
It should resolve your issue, if the issue still persists continue with the following steps
Solution Summary:
Step 1: Connect directly to the wall outlet
Step 2: Paper sizes
Step 3: Clean the paper feed rollers:
Step 4: Reinstall the front panel and check the functionality
Step 5: Power cycle and Semifull reset.
Iris, to isolate the issue I request you to please perform the steps given below:
Step 1:
Connect the unit directly to the wall outlet.
HP doesnot recommend connecting the printer to a surge protector. As they will not provide sufficient power to the printer. So, I request you to remove the All-in-One from the surge protector and connect the printer directly to the wall jack and switch on the printer.
Step 2:
I would like to inform you that the HP Photosmart C5280 all-in-one supports only the Paper sizes given below.
102 x 152 mm (4 x 6 inches)
127 x 178 mm (5 x 7 inches)
Please let me confirm either you are using the specified supported papers or not.
Refer the weblink given below for more information on the product specifications for HP Photosmart 2610 all-in-one.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00954910&cc=us&lc=en&dlc=en&product=3204464&dlc=en&lang=en
NOTE: Clicking the link above may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
After performing the steps check the functionality of the All-in-One. If the issue persist, perform the below steps.
NOTE: After each step, check whether the issue is resolved. Once the issue is resolved, you may stop troubleshooting.
Out of paper error :
In order to resolve the issue please follow the steps provided below:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00786157&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
NOTE: Clicking the links may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Refer the weblink given below for more information on cleaning the paper feed rollers.
Rather than sending you this document in a text format, I am referring you to the Web, where this information is easier to read with graphics and the information is specified in a step by step manner.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpu01831
Step 5:
Photo Paper Loading:
I request you to please Perform the steps provided in the article:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00994721&cc=us&lc=en&dlc=en&product=3204464&dlc=en&lang=en
Refer the article given below for more information on how to correct the envelope printing problems.
Power Cycle:
Please perform the steps provided below to power cycle your All-in-One:
We are performing this step to ensure that the All-in-One receives enough power and all the elements inside the inside the All-in-One are fully charged.
The All-In-One may not be receiving enough power if connected through a surge protector. Plug the All-In-One into power outlet without any surge protector between the All-in-One and the wall jack.
1. Verify that the unit is switched on. Unplug the All-in-One from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Now check the functionality of the All-in-One.
Semifull Reset:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Posted on Sep 12, 2009
I bought a new printer
Paper always packs up in the blades and it will not cut more than 1 sheet at a time. Sometimes not even that. Any solutions for this? I constantly have to dig the paper out of the blades, even after...
All x-cut shredders should be oiled. Buy some shredder oil ( this is a lightweight oil ) from your local store then pour some of the oil across the cutting blades where you insert the paper. After putting the oil in run the machine in reverse...this will help get the oil all thro the cutting mechanism. Then start shredding 1, then 2, then 3 etc, etc sheets at a time...when you hear the motor starting to "labour" to take the sheets thro'..then you have just about reached the point where "thats its maximum". You should occassionaly shred a sheet of paper with a bead of oil on it ( in an "S" pattern) to help keep the mechanism lubricated. Running the machine at about no more than 75% of its maximum capacity and regular oiling will prolong the machines life.
Dec 15, 2010 | Royal VF1012mx Shredder
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Spooler turned off
The print spooler servie might be turned off.
Click on start go to run type services.msc
locate print spooler double click it and then select startup type automatic and then click on start. close all the windows, restart the computer and then try again it should work.
Jun 22, 2010 | HP Photosmart C5280 InkJet Printer
Single sheet paper on my HP LJet 1100a works fine
There is a recall fix on this printer if it has specific feed problems like pulling in multiple sheets etc. Might be related. You can contact HP and they'll send you a DIY fix kit to replace the rubber that pulls the sheet in and onto the rollers.
Feb 07, 2010 | HP LaserJet 1100 Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
Won't even print test page
try to unplug machine for a couple of minutes. make sure that it is not out of paper,(sorry I have to make sure of everything). Let me know what happens.
Oct 28, 2007 | Brother HL 1430 Laser Printer
Paper jam light constantly on.
After hours of trying to clean the machine, repeatedly pressing the OK and other buttons, banging the machine and deleting the driver, I finely got the light to go off. What worked was turning the machine off then turning it back on with paper in the hopper. It fed one sheet of paper and the light went off. Hope this helps someone.
Mar 18, 2007 | Canon PIXMA MP170 All-In-One InkJet...
459 people viewed this question
jasbo
jasbo
