Question about Dell E152FP 15" Flat Panel LCD Monitor
Problem with Dell E152FP Monitor
My Dell E152FP Monitor would come on then the screen will come up and then go black and the power botton start flashing green on and off.
  • 3 more comments
  • Anonymous Apr 29, 2008
    I have two of these Dell E152FPb and they both have the same problem of lights for a few second then black. Image is still on sceen, tubes are out. Replacing 1000uf did not help. Anyone else had this problum with the back light circuit?
  • Donald Keene
    Donald Keene May 25, 2008
    I have the same Dell LCD monitor listed, The one I have comes up nice and bright for about 2 seconds, and then goes dark. The power LED is steady.
    Donald
  • Therese23 Jun 10, 2008
    the monitor is black but the power button is green, cannot see any image at all
  • TurboHatch85 Aug 02, 2008
    mine turns on, then goes yellow and says power save on. took apart and none of the capacitors are bulging. and if none are bulging, which one should i just try to replace and see if helps? there are many 1000uf 16v capacitors on this thing.
  • Emmye May 20, 2013
    Yes Use a flashlight to turn your brightness down to 0 then you can restart it and dont put it about 70 ish or what ever it take to turn it black again !
  • 4 Answers
If you open the monitor up, on the inverter board is a 1000uF 16v capacitor that goes bad. If you replace that it should fix the problem. Look at the top of all the capacitors and you should see one that's popped up on the top, that would be the bad one. Some soldering is required. Make sure you put the negative white stripe on the white side of the silk screen on the board! Its a simple fix just sounds difficult.
Posted on Jan 13, 2008
  • Lawrence Fuller Mar 14, 2011
    Same problem with my monitor. No bulging caps. But, using an ESR meter, C606 - 25v 100uF and C708 - 10v 1000uF were 'out of spec'. Replaced both of them and monitor came back to life.
I have a Dell 1905FP monitor and the screen went black and the Self Test box is floating around. Rebooting does not help. Please help. Rich
Try deconnect and reconnect the screen to the computer. You can also try to use a different cable or port on your computer to connect it. Also, in the "video preference" of your computer, be sure you activate this monitor.
Mar 01, 2011 | Dell E152FP 15" Flat Panel LCD Monitor
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell Flat screen monitor has started to flash the setting main menu on the screen. What could cause this?
It is a problem with menu button.This button is stuck. You can repaired it from service center.
Apr 29, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Screen flickering and going black. Get's dim then goes black
You need to open it up and check the fuse and transistors in the power supply/Inverter board, post back what you see so we can guide you further: http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Mar 18, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Computer was working, then the monitor went black and the yellow lights keeps flashing. The screen also seems to be pulsing. Whats wrong with it?
Have you tried another monitor??
If stil no go then may be video card.
I do not understand "the screen is pulsing"
Jan 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
707 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
