Question about Canon SmartBase MP730 All-In-One InkJet Printer
Banding of colours
Hi I keep getting banding only when I use colour
All new cartridges
Banding when I print in colour... how do I correct
You have to check the settings given to the printer first then confirm whether the toner cartridge of the printer is still good. Thanks
Sep 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Tip
Xerox Phaser 6110 Banding Cure
As usual, my Phaser 6110N (light use, home office network duty, printed less than 2000 pages in the 4 years or so I've had it) developed a banding issue. Rather than invest in a new toner unit, I decided to take it apart and have a look at it. What I discovered is the toner feed mechanism was clogging up and not distributing toner to the imaging drum.
This is a messy job, I did it in the bathtub (dry of course!), and it's simply a case of removing the side covers from the imaging unit (I'd recommend putting the drum in a thick black plastic bag to prevent overexposure) taking care not to lose any parts, and sliding the toner feeders out of the unit. You can then remove the top cover and it will allow you to clean out the mechanism with a small dry paintbrush.
Remove just enough to de-clog the mechanism, and especially the feed conveyor at the back - this takes toner from the cartridge and feeds to the roller screws that feed the imaging drum.
If you've only got banding problems with one colour, only de-clog that particular colour. It's messy and no point wasting expensive toner! Black and red where problems for me, in both cases the conveyor mechanism was chock full of toner and there was very little in the feeder roller screws.
Re-assemble the imaging unit and run a couple of test patterns through the printer. You'll probably find that the first few pages are especially faint - when you first power up the printer from new, it fills the feed mechanisms from the toner cartridge, I haven't found a way to make it do this again (maybe someone can hack together a maintainence firmware update?). The more you emptied from the feeder, the longer it'll take to even it up. Once it's got the page mostly covered, you're back in business.
After I'd done all this, my banding problem went away! Of course, the bath was covered in toner dust and it took a while to get rid of it all!
on Jul 07, 2011 | Xerox Phaser 6110 Laser Printer
My epson stylus SX200 2C will not print black , i have replaced the ink 3 times and cleaned it - it has a lot of gaps and sometine doesn't print black at all. Colour is fine. Help please .
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Banding Scanjet 2400
You can Download the Drivers and the Software from the folowing Link
http://software.canon-europe.com/
Good Luck......
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Severe banding
u better check the haftone test first,when printer starts to pict the paper,just let the printer to print paper,stop the paper before entering the fuser unit located back side,if the output is perfect,then it is the problem with the fuser assy,pls revert for further solution or query
Jul 19, 2008 | HP LaserJet 2500L Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon SmartBase MP730 All-In-One InkJet Printer Logo
old marine
old marine
