Question about NEC E132 Cellular Phone
Don't know phone code for NEC e132 The PIN is accepted as correct, then I'm told to enter the phone code. 0000 doesn't work. Is it possible to reset the phone to the factory code? If so, how
I dont know the pin code
Hello ! Does your phone asking to enter code during start up ? If no you can generate the code with the help of this trick How to Generate Your Phone Security code..Only for Nokia bb5.But for pin code you can enter 0000 if it doesn't works better to contact sim card provider because repeated enter of wrong leads to PUK/Sim Card Rejected.Good luck.Thanks for visiting fixya
Jul 03, 2012 | Nokia 5130 Cellular Phone
Default pin
Hi Dawn,
The default pin is usually attached to your router. If you don't know where to locate that, use the following steps:
  1. Enter 0000. This is usually the default pin.
  2. If that doesn't work enter in a bunch of numbers. After awhile the system will provide you with a reference number and a Nintendo phone number that will fix your problem.
Hope that helps!
Feb 09, 2012 | Nintendo Wii Console
I need the pin code.
Hi try this and let me know:
Enter the default security code: 12345. Only try this once.
if that don't work try this. It works with Samsung phones not sure with Nokia
turn phone on without sim, type:
*2767*3855#
it will reset the code to 0000.
Jun 29, 2011 | Nokia 2730 Cell Phone
Where can i get a replacement battery for NEC e132 cell phone?
You can click on the link below for assistance
http://www.batteries4less.com/nec/nec_toc.html
You can also approach the vendor from whom you purchased the phone.If it is still in guarantee period he'll offer you a new battery!
Mar 11, 2011 | NEC E132 Cellular Phone
Need NEC E132 phone code
Have a look at this see if it helps
http://www.mobile-t-mobile.com/mobile-network/nec-unlock-codes.html
Try it its free, all the others you have to pay for!
Dec 10, 2009 | NEC E132 Cellular Phone
Unlock code for nec e132
You can get the unlock code here http://www.theunlockspot.com/ and also get the unlock instruction in the same site.....By using this you can unlock easily...
Jun 26, 2009 | NEC E132 Cellular Phone
Phone code locked!
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call your phone service company, they can retrieve the puk code from a database
for free.
In your case you need to contact your SIM card phone provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone should not ask for the PUK anymore.
thank you,
Mar 27, 2009 | NEC E132 Cellular Phone
Nokia N70
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the make and model of phone, the network that the phone is locked on, and the country the network is from. Then I will give you the codes. If this is what you want.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. The unlock code varies from individual Handset to Handset, and Network to Network.
Which is the one that you want?
Apr 07, 2008 | Nokia N70 Cellular Phone
Code problem
please use ufs 12 software for reset ur password
Feb 25, 2008 | Nokia N70 Cellular Phone
Resetting PIN on Nokia 6070
Most codes on phones have a generic code of "0000" or "1234" or "123456". try that as the PUK code. If not, contact the manufacture and they can give you the unlock code.
May 22, 2007 | Nokia Mirafone OP201 Phone
NEC E132 Cellular Phone Logo
121 people viewed this question
Top NEC Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
