Question about Cartoni Photography
Cartoni head serial number GM01292. What model is it?
I have an old frame cannot identify serial or model C55829
Not usually possible to ID a bike by serial number alone. Only a few brands have serial number that are unique enough to tell what brand they are, and even if you know the brand the serial number will rarely tell you the model, only the year. If there's no head badge (name plate on front of frame) or model decal then it does not matter at all what brand it is. Value is minimal.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Sep 29, 2017 | Cycling
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Who made this bicycle frame?
most likely a trek. Google Trek serial numbers for more info.
Jan 01, 2016 | Cycling
11.5 Briggs Straton Poulan riding mower, location of MFG serial number
Depending on which your needing. The body model and serial decal is usually located either on seat or on the body under seat.
If it is the engine it depend if OHV or a L-head engine. OHV serial (date code) is on the valve cover. L-head is located somewhere on the engine's flywheel shroud.
Mar 11, 2015 | Poulan Garden
How do I find the make of my guitar based off of the model and serial number of the guitar?
Did you try google? Type the model number and the word guitar.
Oct 08, 2014 | Music
I need a guide pin for a cartoni b511 quick release plate and i can not find one
If you are looking for a non-threaded 'locating' pin to stop smaller video cameras from twisting on the plate...Cartoni does not make one!!! You will either need to mickey mouse something or purchase a new camera plate from another manufacturer that offers this. Luckily this plate is a standard 'Euro' plate used by many video tripod manufacturers. For example, I know the Miller cat# 860 will take a cat# 493 DV carriage which provides not only the 1/4-20" screw but also the locater pin as an assembly.
peter
Jul 02, 2012 | Cartoni B511 Quick Release Plate
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Where do you find the model number and serial number on a Yamaha Electric Guitar?
the serial number is the model number and is usually stamped on the back of the head or on the metal plate that holds the neck to the body
Apr 18, 2011 | Yamaha Electric Guitar
Photography Logo
Top Cartoni Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Cartoni Photography Expert? Answer questions, earn points and help others
