Question about Connex 3300 240-Channels Base CB Radio
Channel light wont come on. can not key up or
Channel light won't come on. Can not key up or receive. Meter light works. Does anyone know the problem?
  • 20 Answers
Hi there!!
It looks like your problem would be your Voltage regulator has either went bad or if your radio is mounted in a truck that vibrates alot then one of the three legs of the Voltage regulator has broke loos from the board. If you do not have experiance in electronics or soldering you should let a Radio Tech. do it for you or you could damage the radio!!! If you choose to do it your self then you must disconect from power then take the covers off of the radio. Turn the radio up side down and look inside the radio you will see the PC board has many compnents inside and beside each one there is a letter and numbers followed by the letter. look to your right and you will see a smaller PC board mounted to the right side with 2 screws to the out side of the chassis. Remove the 2 screws and carfully move the board out of the way so you can see the main PC board. Look down on the right edge of the main PC board and you will see a small black transistor with 3 legs on it the number on the PC board is TR41 when you find it turn the radio over and inspect the 3 legs that are soldered to the PC board and look for a crack or loose solder joint if you find one resolder it or resolder all three legs. If there is indeed a crack or bad solder joint then resoldering it should bring it back to life again!! If not then you may need to replace it with another one!! There is another transistor not to far fron the voltage regulator that may have went bad too it is TR40 that works with the regulator but is unlikely the problem but you never know. Try TR41 first it should fix it for ya. Feel free to E-mail us with any other questions that you may have at: bigdscbshop@hughes.net
Thanks Dennis
Posted on Sep 20, 2009
I don't know how to use this.
you hook a jumper wire from your radio to radio input of the meter . Then hook your antenna to the other side of the meter., Turn the radio on to channel 40 make sure your meter is set for for,now key the mic.make the adjustment to cal on meter. Now put the meter on ref , key the mic and write down that number. Now go to channel 1 and do the same. If your numbers are under a 2.1 you are ok. you should also check it again on channel 20 or 19.
Dec 03, 2012 | Radio Communications
Installation instructions or owners
Hello
The screen voltage to screen grid of the CRT is above than normal. Try to adjust it by adusting screen pot meter, can be located on its LOT.
Mar 02, 2012 | Televison & Video
No power to the speakers no sound
only the left speaker out wont work on either a or b channel anyone know email me mikeyandjessie12@aol.com could it be the speaker wire its 10 gauge speaker wire so idk either channel ive checked its only the left out so i can only listen to the right out on each channel and i cant listen to both channels but does anyone know if you might be able to get a 4 in av cable to a 2 av cable and run 200ws out of this or no
Nov 14, 2010 | Technics SA-EX140 Receiver
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 12, 2010 | Cobra 29 LTD CB Radio
Denon DRA-397 - the stand by button light is blinking red and I have tried the reset but it did not work. Does anyone have any other ideas?
You may want to check your output transistors,They are the ones mounted to the big heat sink.With a ohm meter measure across one of the legs to another there should be no shorts.If you see anything burnt that channel will be bad causing the unit to stay in protect mode to prevent futher damages
Feb 18, 2010 | Denon DRA-397
Radio lights up, but no TX/RX.
Hi and welcome to FixYa,
Based on your description, a possible drift in the local oscillator.  Check the 10.24Mhz crystal filter and its local oscillator for output and consistency.
Good luck and thank you for asking FixYa.
Aug 24, 2009 | Cobra Radio Communications
When mic is keyed, TX light illuminates but power meter does not
make sure your s/rf switch is in the right place on the radio is the most common problem i have found
Feb 05, 2009 | Radio Shack TRC-447 CB Radio
Cobra 29 LTD classic LCD channel display replace
Hello, the channel display is kind of touchy, as far as getting to it and of course it is soldered to a small circuit board and there is a certain way it goes back in. There is about 9 legs on top and 9 on the bottom that need to be unsoldered and resoldered( carefully). You can buy them in red,green, and bue. The meter light is pretty straight forward. You have a hot and ground wire. I used to use colored LED lights in the meters, way cool. They are not hot, and they last almost forever. The LED's are fairly easy because if you hook it up backwards, it just won't do anything. Let me know if you feel comfortable doing the solder work, and take a look inside the bottom cover at the channel selector because it has to come out with the channel readout. I used to charge $25.00 just for that because it would take me an hour just for the ch. selector, and about 15 min. for the meter light. Let me know one way or the other,,, Mechanic
Nov 03, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio won't work on my Denon Receiver
Hook up a Small piece of wire Coming off the #00 ohm input for ant also put it in Mono mode first and you should be able to Hear Hiss Then tune Let me Know ttech
Jul 20, 2007 | Denon AVR-2106 Receiver
Connex 3300 240-Channels Base CB Radio Logo
97 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
