Screen is green - Televison & Video
You might have a faulty HDMI cable--I just had this same problem: audio was fine, but TV was green-screened. I tried everything, finally opting for last-generation multi-colored cables (one double-ended yellow, white, and red, and another blue, green, and red). Believe it or not, this solved the problem. Resetting the TV is another option--use your original TV remote and look for Reset under the menu options.
Posted on Jul 14, 2010
  • 294 Answers
Hello There can be different issue for the problem let me tell you one by one. 1. The green bias transistor has blown i guess. 2.The green gun is sorted to heater element in the neck of the tube. so Go to OSD and give a relook at it. Please do see an experiance tech. guy who has experiance in flyback transformer or cant access the hidden factory menu for frequency adjusting or vertical and horzontal positioning. also try Unpluging the cords for 3 to 4 hrs and see what happens. but its not the final solution. so see and expert. Have nice time. Gizokieth
Posted on Sep 11, 2009
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Jun 06, 2009 | Polaroid FLM-2011 Television
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Sony Office Equipment & Supplies
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Dec 21, 2007 | Televison & Video
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
Sep 12, 2007 | Insignia IS 20" TV040919 TV
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Jul 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
1,929 people viewed this question
Top Televison & Video Experts
Electro Med Services...
