Question about Brother MFC-5840CN All-In-One InkJet Printer
MFC 845CW all in one
Had for 4 mo. worked ok yesterday stoped remote hand set says thatbase not detected ,,, tried to re install per book does not work .., with phone on reciever base answer part does not work ???????
  • 832 Answers
Try to unplug machine from power outlet. Wait 2 min. then replug again. Check settings.
You may take a look here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc845cw_us&Cat=18
If it doesnt work, plz call brother hotline for further instructions.
Posted on Jan 25, 2008
  • Jaspal
    Jaspal Oct 31, 2013
    When you get this error and all previous 4 base unit slots have been used up, on the printer press then then then press ...from the handset then do and should work
  • Jaspal
    Jaspal Oct 31, 2013
    When you get this error and all previous 4 base unit slots have been used up, on the printer press 'menu' then 'intial set up' then 'Register Handset' then press 'Register'...right after from the handset then do 'Register HS' and should work
Printer screen reads unable to print 50on my MFC-845CW
I would reinstall the driver and see if that first fixes the problem. be sure to restart the printer and the computer after installing the driver.
You can find the driver from here:
http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=MFC845CW
Jul 15, 2011 | Brother MFC-845CW multi-function...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
I have a Brother MFC-845Cw which has fallen breaking the printer display, is it possible to purchase a replacement and install it myself, if not what would it cost me to get it fixed and would it be worth...
Yes replacement of the display board can be done provided the damage is limited to it as after the display is set in if there is any more issues you might be stuck to go forward by spending more.
So iwould advice that you get the printer estimated at teh brother service centre as they can swap and confirm.
This will be better as you can get and estimate with a confirmation with which you can decide..
Sep 25, 2010 | Brother MFC-845CW InkJet Printer
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-845cw error unable to print 4f
Hi there
Ok try see if this work.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 06, 2009 | Brother MultiFunction Center MFC-440CN...
I need my printer
do call brother hotline of your country. they will give you a hand. see www.brother.com and choose your country.
Mar 18, 2008 | Brother MFC-845CW multi-function...
Brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Feb 29, 2008 | Brother MFC-845CW multi-function...
MFC 845CW Not Printing Via Wifi
have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc845cw_us&Cat=8
Dec 28, 2007 | Brother MFC-845CW multi-function...
Brother MFC-5840CN All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
