Question about DEI Valet Keyless Entry System
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
    New Friend:
The remote start control has a lock button, unlock button, aux button, and a yellow button in the center which is the remote. All buttons work but the remote (yellow button) wont start the car
Posted on Dec 13, 2013
    Problem Solver:
  • 13 Answers
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Posted on Oct 29, 2009
  • Dean Papanik
    Dean Papanik Dec 13, 2013
    The remote start control has a lock button, unlock button, aux button, and a yellow button in the center which is the remote. All buttons work but the remote (yellow button) wont start the car.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Replaced battery now nothing works,doors dont unlock,car doesnt start,no sounds when pressing buttons although it still sang when battery replaced,pressed "P" button hoping it would do something and now it...
The waves mean that the remote is vibrate mode. Try reprogramming the remote. Open the door, turn ignition on, press and release the valet button once then, press and hold the valet button. press the lock button on the remote. Vehicle should respond with a chirp from the siren. Release valet button, turn off ignition, test system.
Jan 17, 2014 | Directed Electronics 479V Remote Gen 2...
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
I have a 04 Chevy Trailblazer with the 5501 installed. This morning I got up and started it up with no problems, this afternoon I go to start it and I get the remote start error. There's no flashing of the...
you can try and reprogram the "tach". it sounds like the bypass module is working since it controls the lock/unlock function as well as the bypass for passlock III. to reprogram the tach you need to start the car with the key and within 5 seconds press and hold the valet button, the parking lights should flash to confirm tach has been learned. remove the key and try the remote start. if all is well, cool. but if it still doesn't work, put key in ignition, turn key to on but not start. with key in the on position remote start car with remote, if it starts then the problem is your by-pass module. hope this helps, dave
Jan 12, 2011 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
My led light for my alarm stays on and the alarm dont work anymore but the button still locks?unlocks/and starts
Your system is in valet. To take the system out of valet with remote: open any door, press lock, unlock, lock. Now check the LED; it should be off. Close the door and arm the system to check.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and arm the system. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
Doors lock and unlock, but system will not arm. also the red LED is on untill the car starts. How do I get my system back up and running?
The LED light is on solid until you start the vehicle. Sounds like the alarm is in valet mode. Try opening any door, press lock, unlock, lock. The LED light will go out if the system was in valet. For future reference, that is the process for "remote valet". If that does not work, turn igniton on then off, within ten (10) seconds, press and release the valet switch. The LED will go out if the system was in valet.
Nov 15, 2010 | 3100L 1way Security System
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
My Python 990 system is acting up.Installed several months ago. Now doors wont lock or unlock and alarm goes off every time the door is open even in the unlock pososition. The vehicle is a 2002 Escalade...
Sounds like you have a bad remote, bad battery in the remote, or it needs to be reprogramed to the alarm. If the alarm has been set with the remote, it will need to be disarmed with the remote as well, unlocking the door with the key and getting in, will set off the viper. If you know where you valet switch for the alarm is(small black push button), just turn the key forward till everything on the dash lights up, push the valet switch for about one second and let go. The alarm should shut off in a couple seconds. This will allow you to drive the car until you get you remote checked out.
Aug 15, 2009 | Directed Dei Valet 561r Remote...
2005escalade remote starter
did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Dec 19, 2008 | Directed Dei Valet 561r Remote...
DEI Valet Keyless Entry System Logo
1,139 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
