Question about Emerson EWC1902 19 in. TV/VCR Combo
I can't find out how to switch the TV from cable to antena. Where is the switch?
    President:
  • 1,187 Answers
If you have the original remote, it is the "source" button.
If not there, select menu and go to the source option and select "antenna", then press menu again to save & exit.
If no remote, the on the TV, press thge menu button and go to the source submenu and select "antenna".
At this point, you may want to do an automatic channel scan before you exit the screen via the menu button.
Hope this helps!
Posted on Sep 11, 2009
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Do i need to buy a converter box for this tv
No,this tv is a digital tv,just reqiure a good antena like a digital antena or a roof antena.Hook it up.Just go into tv menu setup and set up to pick up AIR not CABLE and enter to scan for DTV free air channels.
Feb 01, 2011 | RCA L26WD26D 26 in. LCD TV
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Cannot receive channels past 99
Is this free over the air signal?Get a better antena like a roof antena or digital antena.Rescan again after everything hook up.If this Cables,satalites,or telecom signals,unplug,replug the box for bootup and software
upgrage,go to ur tv menu make sure it on cable setting,rescan it again to get all fresh channels.
Nov 04, 2009 | Symphonic ST420FF 20" TV
Disconnect power antena
I just removed the motor for the power antena and pulled a regular one from a junk yard. Very simple brackets, a couple of bolts each. With the cable, it is just a coaxial like your tv cable from the cable company, I just split it and put the same connector as I would the tv cable on each end, then I put a double female connector in the middle.
Hope that's clear enough.
have fun with it.
Jan 19, 2009 | 1999 GMC Savana
Dtv switch
yes if runing sat or cable, if your using antena you will need dtv antena and dtv box for reception.
regards,
daniel.
Jan 05, 2009 | Akai PT5598HD 55" Rear Projection...
HD cable question
i have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
Dec 03, 2007 | Polaroid FLM-3232 Television
Emerson EWC1902 19 in. TV/VCR Combo Logo
132 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
