Question about Logitech Harmony 890 LCD Remote Control
No charge on the remote. already bought new battery.
One blogger said that the main issue was the contacts on the back of the remote itself. And to take the remote apart and push the contacts back through. But besides the two small screws on each end, how do you open the remote???
    Novelist:
  • 76 Answers
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together. Good Luck!!
Posted on Mar 06, 2010
Please note that if you take your remote apart, it will void the warranty.
You can see my post at the following link to try a workaround for this issue.
http://www.fixya.com/support/r4272044-harmony_remote_not_charging
Hope it helps!
Posted on Mar 05, 2010
Why keyless entry system does not work?
Take it back to the garage where bought for them to fix!
Oct 08, 2015 | 2005 Dodge Dakota Club
Where can I get my 890 repaired in Reno, Nevada? The battery will not hold a charge and the screen will not display.
I can't help you find a repair shop, but if you have not tried the following, do this first before anything else:
Are you sure it's the battery and not the charging cradle?
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together.
Now, for the screen, sometimes putting the remote in 'safe mode' and doing a firmware update will bring the screen back to life. Here's how:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many LCD display issues. Good luck!
Feb 10, 2010 | Logitech Harmony 890 LCD Remote Control
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
The best advice would be to update the BIOS and then go to the BIOS utility and restore the settings back to default. This might resolve the issue if it is software related. If not then visit the manufacturer's website and download the latest chipset drivers. Restart.
Try using a different power adapter of the same kind and check for the issue.
Turn off system and remove the power cable and battery and press the power button for about 30 seconds to power drain the system.
Turn on and check.
If not the main board itself is the issue for which I would request you to contact the manufacturer.
Sep 10, 2009 | Computers & Internet
I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Aug 10, 2009 | Canon PowerShot SD1000 Digital Camera
I even bought a new battery and the remote still will not charge.
not the battery. open the base and raise the three little brass charging contacts. i used a file to shave the plastic on remote contacts to get it to seat better on the base. if you mash on the remote while on base and it starts to charge then do the mod.
Jul 02, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech harmony 880 won't charge
Clean the leads on both the charger and on the remote itself with rubbing alcohol.
We had this problem (it would lose connection periodically for no apparent reason, then eventually wouldn't even register that it was set down). The leads sure looked clean, but shining them up with rubbing alcohol (recommended on one of the Logitech boards) got it to start charging again.
Mar 31, 2009 | Logitech Harmony 880 LCD Remote Control
Shuts off by itself
Your unit may have a defective button, particularly on the power but loose contacts on the main component is the most that can cause the issue .
Have the main circuit be resoldered for loose contacts.
chris
Feb 14, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Ipod won't work unless plugged in to computer or mains
alison65,
good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
1) The connection of the rechargeable battery inside the player is loose or out of contact
2) The rechargeable battery itself is faulty
3) The connection from the charging line is loose or out of contact
most likely your problem is within the internal of the unit.
cheers,
mark
Jan 29, 2009 | Apple iPod nano
We have a logitech 880 Harmony TV remote. It will not hold a charge. We bought a new battery and that did not help. It will not do anything Now it says "safe mode requested" AA681, B2390.
Assumption: the remote did not in any way receive physical damage including any sort of moisture or liquid inside.
Aside from you replacing the battery which you already indicated, I would recommend you contact Logictech technical support.
One more thing you may want to try is to take a soft pencil eraser and make sure the three gold contacts are clean by rubbing each with the eraser to insure good contact when sitting in the charge cradle.
Nov 20, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
85 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
