Question about KitchenAid KCMS185J Microwave Oven
From the time we had our microwave installed, it would not pop 2 bags of popcorn. It would shut down about 28 seconds before the 2nd bag was done. We had an electrician out and he couldn't figure out the problem. We called A&E, whom we have a service contract with. ?They sent a man out and he said it was an electrical problem in our kitchen wiring. Yet he ordered parts for our microwave and came back out and replaced some. He decided not to install the new electrical panel. This all took several weeks. Same problem. We called another electrician and he discovered by measuring wattage and output with his tools that the microwave is defective. The power drops way down when popping corn. Then it just shuts off. Several times it has tripped the circuit breaker. A&E says our warranty is NOW expired and we would have to pay the service calls and parts. We're very angry about this. The technician didn't do a thorough job when we were still under waranty. Any suggestions?
    President:
  • KitchenAid Master
  • 1,922 Answers
Can you prove with documents and bills that the a&e tech mis-judged repairs? if so send them to the microwave manufacture w/all repair bills and they might give you some relief
Posted on Sep 11, 2009
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
Oct 29, 2013 | Magic Chef CMV1000B Microwave Oven
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
We can't get our microwave to fully pop the bag of popcorn. If we use the popcorn button it stops before the bag even starts popping. If we preset the time, the same occurs and if we run it until its...
Always place the bag of popcorn on an upside-down paper plate.
This allows more microwaves to penetrate the bag from the bottom.
Also always place food of any kind in the microwave off-center on the tray, NOT in the middle of the tray.
Not only does it cook more evenly (think of how you stir liquid) but it also prevent the same spot from being heated repeatedly on the glass turntable, which can lead to overheating and breakage.
Sep 06, 2010 | Dacor DMT2420SS Microwave Oven
Over heating and shuting off
I am not surprised! Cloth of anysort is not recommended to be placed in a microwave oven!
That includes undies and socks which many try to speed the drying time of.
Regarding the popcorn.. The oven is overheating due to a possible containment in a hutch, where insufficient airflow is available to lower the temperature. Pull the unit away from the wall to allow more airflow, clean the vents and help it breathe.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Over the range microwave
I would return the unit and get a different model or brand if possible.
Jul 07, 2008 | Microwave Ovens
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave
That's probably because there's still steam (humidity) in the cavity after the first bag is popped.
After the first bag pops, try wiping down the walls and ceiling and leaving the door open for a couple of minutes.
You might even blow or fan the air out of the microwave.
Jan 02, 2008 | Panasonic NN-C980 Convection/Microwave...
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
KitchenAid KCMS185J Microwave Oven Logo
55 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
