Question about Epson C31C412144 Thermal Printer
Hello I am trying to get my M129h to print from my amigo POS it is in dire need for business tonight! Settings on printer are: The small switches under the DSWI panel located under the printer are set to: on then 2-8 on then 2-8 should these be changed and if so which ones? Settings on POS for this printer are: General: Generic/Text Only Letter/600 dpi Sharing: has current driver and is a shared printer but right now is connected for diagnostic purposes to just one pos atm Ports: COM4 Serial Port Generic/Text Only,bar2tm (name) Advanced: Always avail priority 1 Driver: Generic/Text Only Spool print doc so prog finishes print faster start print immed checked boxes: Print spooled docs first Enable adv printing features Print Processor: WintPrint Raw Printing Defaults: Portrait Front to back pages per sheet 1 Device Settings: Form to Tray assignment: Cont. Feed - No Break: Cut Sheet : Letter Cont. Feed - w Break: leter Printer Commands: Nothing entered except .01mill Font Selection US (ANSI) (1252) ANY HELP MUCH APPRECIATED!!!
SOURCE: ePSON m129h pos PRINTER -- NOT EJECTING AND TEARING RECEIPTS
Finally used the hardware trouble shooter in my POS software program. Disconnected all the connections to the printer, shut down the program and workstation. Plugged things back in and YEAH!
Posted on Jan 15, 2009
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
ohms
  • 1879 Answers
SOURCE: "Generic / Text Only" driver printer and cyrillic
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Posted on Feb 26, 2009
  • 16 Answers
SOURCE: Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Posted on May 27, 2009
57 varieties
  • 1653 Answers
SOURCE: TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Posted on Aug 29, 2009
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
Hi! I installed new ink cartridges almost a month ago and that same day I had no problem printing. 1 week later it was printing extremely faded. Thought it was a fluke, but tried again tonight and it's...
Hello!
We all as a canon printer consumer is needed to use Pro dot ink to refill. Please remove your cartridge and clean up the cartridge head tightly by soft/toilet paper and replace again. If it doesn't work clean it again and again... thanks
Sep 13, 2011 | Canon PIXMA MP160 All-In-One Printer
The restaurant i'm working for is changing to pc-america's cre pos. the old pos prints the food orders and table #'s in a large font on the kitchen printer. i am looking for a way to configure cre's...
As far as I know, there is no way to change the font settings in CRE (I hope you mean RPE). But, you may be able to change the default settings in the printer itself to get larger print. I am available for tech help if you need it, but you should have 3 months free support from PCAmerica with the purchase. I also do custom menu support for RPE. sysadmin@ccybernet.com
Jan 11, 2010 | Pc America Restaurant Pro Express
I need to down load drivers for my epson M129H printer
Hi calderon1of4
epson m129h printer drivers can be found at
driverupdate us .
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Oct 19, 2009 | Epson C31C412144 Thermal Printer
EPSON m129h pos PRINTER -- NOT EJECTING AND TEARING RECEIPTS
Jan 14, 2009 | Epson C31C412144 Thermal Printer
Scanning/Uploading Issues
in the HP print manager, you can go to scan, settings, and decide where and what format those scans become..if you need more help, then you might consider a shared screen service call with me..
Mar 28, 2008 | HP Photosmart C4180 All-In-One InkJet...
Epson C31C412144 Thermal Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
