Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
Picture blurry
By bobnic on Dec 10, 2007
toshiba 43vj13p comes on blurry then clears when set is warm,can anyone help please thanks
Same Problem
Jan 27, 2009
-   Same problem, picture blurry for 15 minutes then clears perfectly, anyone have an idea what is causing this? -   lpogal2
Nov 10, 2008
-   my tv is blury on the right hand side what could be the problem ??-   jayboy1990
Solution #1
posted on Jan 23, 2008
Not Rated)
ctf1800
Rank: Wiz  Toshiba Expert
Rating: 85%, 4402 votes
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
try doing a magic focus
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
