Question about Whirlpool Refrigerators
I wanna know why my refrigerator is not cooling?
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main ciructit board.
Posted on Sep 11, 2009
  • 60 Answers
Try unplugging the unit let it set for 30 sec and plug it in. If it starts up your good to go. IF it stops again in a few day then you need to contact your repai depot to get an estimate. IF unplugging it doesn't fix it then you still need to contact a repair depot as they have the neccesary tools to check it out and give you an assesment.
Cheers
Al
Kenmore #970-155320 how much cold it has...cant find it its for bed bug killing experiment....
Turned to their coldest setting, most properly functioning household refrigerators can attain minus 6 to minus 10 degrees in a normal (70-78 degrees) room. Room (ambient) temperature affects cooling performance. Colder temps will cause the unit to run significantly more.
Oct 28, 2016 | Kenmore Refrigerators
Frigidaire FRS22ZRF side by side. Freezer works but the Frig isn't cooling. Anyone know what the problem could be?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Frigidaire FSC23F7D Side by Side...
NOT COOLING SUB Z 550
you have either a bad compressor relay or a bad compressor. disconect the power and pull the cap off the problem compressor and there will be 2 components that wires are hooked to. leave the wires on them but pull them off. the one with the most wires is the one that you wanna check. shake it in your hand and if it rattles like it has gravel in it then replace it with a new one. that part is your compressor relay. If it doesn't rattle then you have a bad compressor. The other one with one wire is the overload. It is probably white depending on how old it is. Let me know your modle # and I can get you a part #.
Apr 01, 2009 | Refrigerators
Circuit diagram of refrigerator
i went to the store an bought a two in one relay-overload the diagram on the box shows me how to connect the the compressor but there is two black wire which is the power i want to know how to find the power wire so i can connect them
Feb 20, 2009 | Hoover HCA454FK Bottom Freezer...
Refrigerators Logo
129 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
