Question about Samsung SP-P4251 42 in. Plasma EDTV
Picture wobble on plasma tv
I have the same problem with a philips 42" plasma that is five years old and after a couple of hours the wobble begins. If i turn it off for a while, it stops but begins again when the tv heats up.
SOURCE: 42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Posted on Jun 30, 2007
jdbouncer
  • 72 Answers
SOURCE: Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
Posted on May 05, 2008
SOURCE: Philips PLASMA TV 42PF9956/37 42" power board 3104 313 60173 relays clicking TV does not turn on
The capacitors for 2533,2540,2541,and 2508 should be replaced. They are all 100uf 16v surface capacitors. Those capacitors are sold on amazon.com http://www.amazon.com/Rubycon-Electrolytic-Capacitor-IMPEDANCE-Continuous/dp/B0015A8U9M/ref=sr_1_2?ie=UTF8&m=A6Q8GCHJGURD6&s=industrial&qid=1225140147&sr=1-2
Posted on Oct 27, 2008
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
Shuttle83
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
My Phillips flat screen model 42fd9935/17 has started going black after playing for about 2 hours... you can still hear the sound, but the screen is black... the picture will come back after turning the tv...
The cost of getting this plasma fixed is not costwise compared to getting a new TV. I recommend NOT to get another plasma but get either an LCD or LED for the best quality compared with price. Plasma parts can be quite expensive especially for a 10 year old model or may not be available.
Nov 03, 2011 | Philips 42FD9935/17 42 in. Plasma...
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
My Philips Plamsa won't turn on, has a black screen but the power light is on. There is also a constant clicking noise. Any ideas of what this might be. The tv is a couple of years old.
The picture is White or Black:
1. Adjust picture setting such as brightness or contrast
2. Check the color settings
3. Check to ensure you cable connections are connected properly.
Jan 20, 2011 | Philips 42PFP5332D 42 in. Plasma...
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
5 year old plasma that looses half the picture
Hello. I recommend that you forget the repair for two reasons. 1. Pricey. 2. You still have a 5 year old set with no warranty. In the last five years, the tv technology has come so far. The HD is fabulous. The new sets cost less to operate and they are so much better than they were five years ago. Joe
Mar 24, 2010 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
No Picture or Sound
IF YOU LIVE IN THE UK YOU CAN BY A REAPIR KIT FOR IT , IT COSTS ABOUT £12 FRON CHS POCKLINGTON
Dec 04, 2007 | Akai PDP-4216M 42 in. Plasma Television
Philips Plasma 42" - constant purple haze
if the set is less then a year old it may be under factory warranty.
it sounds like the vscan, vset , or vsus voltages are off..it could also be the panel itself..contact philips
Nov 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Samsung SP-P4251 42 in. Plasma EDTV Logo
193 people viewed this question
Henry  Thomas
Henry Thomas
