Question about Maytag Dishwashers
My wife started the dishwasher normally. Water
My wife started the dishwasher normally. Water began running, then she heard a click and the dishwasher stopped. It could not be re-started, none of the control lights would come on when pressed, the soap cups had not opened, and there's water standing in the bottom. Any ideas?
    Sergeant:
  • 222 Answers
Quite possibly something lodged in the pump, locking it up. Control sensors don't advance timer because unit is not running.
Posted on Sep 12, 2009
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Thanks for the help
there is a float switch in the base which when operated, turns everything off and turns the drain pump on
Aug 21, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Mar 21, 2008 | Dishwashers
Dishwasher
I have not heard of or seen this dishwasher but I do know on a lot of dishwashers if the water is not hot enough it will heat the water and the heating light will come on to let you know. On most models if the washer has to heat the water it will prolong the wash time. It may do this through out the wash and rince cycles. dont be surprized if your dishwasher runs 90 min or longer. This is normal for most all dishwashers now. I would read the owners guide and get to know whats normal for your unit.
Jul 12, 2007 | Zanussi 18 in. DE4744 Free-standing...
Dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Jan 20, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
