Question about Plumbing
Resin in soft water
I have a Culligan Estate 2 with Super S iron filter, about 10 years old on a private well. Over the last year I noticed a slow drop in water pressure and recently started getting resin in my water. Are these related and what can I do to stop the resin from passing through? I've tried to email Culligan but they have not responded and having lost my job 10 months ago I am hoping this is a problem I can fix myself. Appreciate any response.
  • bozcro
    bozcro May 11, 2010
    what is this resin?
  • 523 Answers
Curious if you have had any resent well pump issues, low pressure lost pressure? Has the well pump gone done (possible vacuum created drawing out resin)
Often water softeners will have a bye-pass on them. I would try bye-passing the softener for a bit, run the water (and the pump) for a while clearing your system of any resin. I'd open bath tub valve or better yet an outside garden hose (watch for resin)to avoid plugging a aerator. If you see a significant pressure gain it could be that your softener has some plugging> In some areas of the U.S. Iron Bacteria has formed in aquifers which with time will plug a softener along with piping. If this is happening you will have to treat your well, this is done with chlorine (please use a professional here, we are talking about your drinking water) If this is happening the well will need to be treated once or twice a year.
I hope this may have helped,
Tom
Please start with the bye-pass on your softener, if your water pressure is greatly better you have narrowed down to where your problem is
Posted on Sep 20, 2009
  • RJ H2O
    RJ H2O Jun 21, 2011
    There may be several problems here.
    1. Resin in water indicates there is a hole in the outlet manifold of softener and it needs to be replaced.
    2. Softener will need to be re-bedded also.
    3. Iron build up in the Super S filter will cause severe pressure drop. This system may also need to be re-bedded. 10 years is about the time frame. Set it to regenerate every day for a couple weeks and bleach at least 3 x per week. This may help bring it back.
    The outlet manifold and valve can get plugged with iron on the Super S and cause pressure loss in home. By-pass both systems to see how pressure is.
    4. Keep the softener by-passed until service is performed on it or you will have resin throughout the house and in the water heater.
    RJ
I replaced old non working culligan system with whirlpool 48000 softner three months ago. In the mornings water from faucet has orange tint until run off for about ten minutes. Water feels soft in the...
Cabinet style water softeners (GE, Whirlpoool, Kenmore, Sears) are very inefficient at removing iron. They are not designed for water with high iron content such as yours. I might suggest setting the hardness level up as high as it can go (100gpg). Indications that water softener resin is getting fouled with iron are exactly as you described. Rusty water the day after a regeneration. You may need an iron filtration system before the softener so all the water softener has to do is remove the hardness.
Here is a link for an iron filtration system that works with air. Very simple, works very well.
http://www.water-right.com/residential/wholeHouseFiltration/impressionIronSulfur.php
RJH2O
Jun 19, 2014 | Whirlpool Water Dispensing & Filtration
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
Installed culligan silver series water conditioner that hadn't been used in 2 years. Cleaned the brine tank, water flows well to it yet still get yellowish colored water even after regenerating it 4...
kissfreak-
Yellow water sounds like a problem with iron. Unfortunately, a water softener is designed to remove calcium, primarily. It will remove a little iron but not much. An iron filter system is the preferred method for removing iron.
Regards,
DIYpro
May 30, 2011 | Home
Hard water, salt in in tank, what do i do
Make sure there is not a "Salt Bridge" in salt tank. Salt tank should always be at least 1/2 full of salt.
You may have just run out of soft water, run 2 manual regenerations in 24hr period. If no soft water still. The eductor assembly is plugged with iron or sediment and needs to be cleaned out. The eductor assembly is where the brine is drawn through to regenerate the resin.
RJ
Aug 12, 2010 | Culligan Sediment Water Filter Heavy Duty
I have a culligan canadiana softwater conditioner may not be work
Hi and welcome to FixYa I am Kelly.
Many times on Culligan water softener system installations there is a water bypass / on manifold from the house plumbing to the unit. If you have one it needs to be in the on position.
The soft clicking you hear can be 2 things
1. the timer doing its job actuating the contacts for the soleniods,
or
2. A solenoid being energized to open or close the purge, drain or brine tank solenoids.
If your unit has been idle for 2 years any number of things can be sticking or corroded
a. the brine tank tube opening is can be rock hard and clogged with old salt
b. the solenoid needles that actuate the opening and closing of valve diaphrams can be stuck in the metal casing they slide up and down in.
c. Not likely but the resin tank tube can be clogged
If you don't notice the soapy slick while in the shower / bath then it probably is not working.
A word of advice... if your not comfortable working on a closed sales / service / repair market product it can be costly if you attempt repairs and then call Culligan. I know they have the standard 30 min charge but in the long run they are in and out pretty quickly as that is all they do.
Thanks for using FixYa.
Kelly
Mar 23, 2010 | Water Heaters
Culligan Estate 2 Model 01010091. Back wash will not stop.
The back flow filter is clogged. It will need to be cleaned out. When it is clogged the pressure reverses so the valves will stay open to clean without shutting off
Feb 06, 2010 | Culligan Sediment Water Filter
I'm looking for info on Culligan Super "S" water conditioner. Serial # V06244773 Part# 01014773 Can I get a manual? The water smells like rotten eggs. I need to know does it uptake bleach every 30 days or...
The Culligan Super S filtration system needs to have 1 gallon of 5% household bleach at least weekly. If your water is high in H2S it needs a gallon of bleach with every regeneration. Set the system to regenerate every day for 1 week and bleach at least 3x that week. Super S filters are recommended to be re-bedded every 750,000ppm. Regen cycle example: 2ppm iron, .5ppm H2S this system is set to regenerate every other and use 1 gallon of bleach per week. This system is now 13 years old and has exceeded the 750,000ppm suggested re-bed but is still performing with great water.
You also need to check the water heater to see if smell is coming from there. The anode rod in WH degrades and gives off a sulfur type smell. Here is a link for the Super S manual.
http://www.eculligan.com/support/supS-op-inst-manl-from1997.PDF
RJ
Jan 05, 2010 | Culligan Sediment Water Filter
STEAM FUNCTION STOPS WORKING
You need to replace the descaling resin. I have no idea where to find it, however.
Dec 06, 2009 | Irons
Culligan medalist softener: Water continues to run thru drain line even after regeneration ends. What to do?
Its a most common problem with culligan seal pacs. If your softener is under 5 years old you have the worst softener on the market. Culligan was bought out about 5 years ago by a canada group. they changed every thing and nothing is made in the usa any more. You will have to buy a new one from culligan and pay over 90.00 for it. The old seal pacs lasted 15 years or more now your lucky if you get 2 years.
Nov 18, 2009 | Dryers
Water softener doesn't work properly
Check for iron content of the water in your area. Excessive iron will clog the zeolite beads in your softener and reduce its life. You can try increasing the backwash and rinse cycles to see if it helps. You can also get an iron pre-filter for a softener. I am assuming you have either a private well or a municipal well.
Mar 17, 2009 | Kitchen Appliances - Others
Plumbing Logo
271 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
