Question about Lexmark X5150 All-In-One InkJet Printer
Not printing correctly
Not printing in correct alignment everything is to left of where it is layed out originally. Had an error message this morning? something about cartridges?
  • The Greek1 Dec 31, 2007
    When I print a page, most of the time the Lexmark X5150 will not print the right side of the text. So you loose one or two words all the way down the page. Is this a tab setting that I can adjust?
    Iv'e tried moving the page on the computer screen back & forth. (dosen't help.
    The Greek
    Master:
  • 619 Answers
You can view your printing adjustment by click print preview and then back to window adjust it by use of mouse can align yourn printing alignment.
Posted on Dec 31, 2007
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Printer stopped working. Getting "10" orange flashes for which there is no error answer in the book. Believe driver is up to date. Wondering if I should uninstall program and reinstall. Problem may have...
Mar 27, 2010 | Canon i860 InkJet Photo Printer
My is not working & shows an error code B200.
Mar 25, 2010 | Canon Office Equipment & Supplies
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Message shows: install correct print head
After you do what the error message says then you have to go through the keyboard and clear the error as per the user manual instructions. God bless.
Jan 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer problems
Re-install your HP driver software
Down load and run HP's Software Cleanup Utility.
Please read the instructions first.
Download here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036626&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Nov 19, 2007 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
