Question about D-Link DIR-615 Wireless Router
I would like to set up a pass word to secure my wireless signal; I have an iMac and can't launch the "Instalation Wizard"
  • 21 Answers
Same problem here with a Motorola WiFi router. I had to use a Windows laptop and to set up the router.
Posted on Sep 11, 2009
I need to take the pass word off of the wifi
While it is not recommended to remove the wireless passwording (this makes the network unsecure and anyone can connect within range), if you want to do it, you must do the following:
Open your browser and log into the router configuration.
Under SETUP, select LAUNCH WIRELESS INTERNET SETUP WIZARD.
Click NEXT to continue.
Observe your SSID. You can leave it alone or change it now.
On this screen, to disable wifi password security, select NONE and then click NEXT to continue.
Continue to the end of the wizard, following prompts as necessary.
When complete, click APPLY SETTINGS to save all changes.
Exit browser.
Dec 01, 2013 | D-Link DIR-615 Wireless Router
Download smart wizard instalation assistany wgt 624
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 25, 2013 | NetGear WGR614 Router
How to remove a router security key from a DIR-655 D-link router?
Please follow the below steps to remove the security key from your wireless router DIR-655.
1. launch "Wireless Security Setup wizard". by clicking on setup.
2. Click "Next" , You will get a screen giving you an option to select the security level.
3. There you can select "None - No Security". & click on "Next & then click on "Save".
This would remove your security key from your wireless router.
Regards
Oct 11, 2010 | D-Link DIR-655 Wireless Router
Security key
Use an Ethernet cable to connect your desktop/laptop to one of the LAN ports on the router. Launch Internet Explorer, and connect to the web-server "inside" the router. Run the "Wireless Networking Setup Wizard", to enter an SSID, enable 'WPA' encryption, and to set a security-key or password or pass-phrase.
Aug 22, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a DIR-625 N router and am unable to secure it
Hi dakingma1221,
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
You may also connect using the NetBIOS name in the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. Type in the graphical authentication code (if you cannot read it, click Regenerate).
To run the security wizard, click on Setup at the top and then click Launch Wireless Security Setup Wizard.
Click Next to continue.
Enter the SSID (Service Set Identifier). The SSID is the name of your wireless network. Create a name using up to 32 characters. The SSID is case-sensitive.
Select the level of security for your wireless network:
• Best - WPA2 Authentication
• Better - WPA Authentication
• None - No security
If you selected Best or Better, enter a password between 8-63 characters.
If you selected Good, enter 13 characters or 26 Hex digits.
If you selected Better, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
Click Save to finish the Security Wizard.
If you selected Best, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
If you selected WPA-Enterprise, the RADIUS information will be displayed. Click Save to finish the Security Wizard.
Good Luck,
Don't forget to leave a rating,
Thanks
Mark
Sep 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do i make my speedstream 6520 wireless?
"If your PC has not been connected to a broadband modem or other network device, you will need to
perform the PC configuration procedure below. Remember to restart each PC when finished. If your
PC has been connected to a broadband modem or other network device, continue to the “Using the
Wireless Connection” section below.
1. Start your Web browser. In the Address box, enter the following: »speedstream.
2. Press Enter. The SpeedStream Simple Setup Wizard will launch.
3. When prompted, enter the Internet connection information provided by your
Internet Service Provider.
4. At the end of the Setup Wizard, you will be given the option to either connect to
the Internet or further configure the optional settings of the gateway.
5. If additional configuration is desired, select the icon for the service or option
you wish to configure: the gateway’s firewall and security settings, User
Profiles and content filtering, or home network options."
"Using the Wireless Connection
By default, the SpeedStream® Gateway is configured to work
seamlessly with other SpeedStream® wireless products. The default
wireless interface settings are:
SSID: SpeedStream
Channel: 11
Mismatched wireless settings will prevent successful
wireless network connections between devices, so
you may need to reconfigure some wireless settings
to ensure that all settings match between wireless
devices if you are:
a) Using another manufacturer’s wireless products
b) Adding the SpeedStream® Gateway to an existing
wireless network
The Setup Wizard will walk you through setting up wireless settings."
Jun 14, 2009 | Computers & Internet
How do i secure my dir-615 router
1. Log into the router by typing 192.168.0.1 in the address bar of your browser.
2. User admin for the username and leave the password blank (unless you have changed the username and password, if so use your custom settings)
3. Next run the security security wizard: Click Setup at the top then click Launch Wireless Security Setup Wizard.
4. It will take you step by step to set up a secure wireless network.
I would also suggest you change the router password while your in there to prevent others from accessing your router using the default setting if you have not already changed it.
You can download the user manual for the router at:
http://www.dlink.com/products/?tab=1&pid=DIR-615&rev=DIR-615
Happy Surfing!
Jun 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can not remember or find network security key
You may need to access the router's setup page to check the security key or the network key you have set up to the router. To do this:
  1. Launch IE and type 192.168.1.1 on the address field using a computer that is wired to the router. It is the default IP address of the router. It will then ask for a username and password. By default, there is no username and the password is admin.
  2. Once you're in the router's user Interface, click Wireless tab. There is a sub-tab under Wireless which is called Wireless Security. Click on it.
  3. There you will find the type of wireless security you have enabled in your router as well as the network key.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
D-Link DIR-615 Wireless Router Logo
104 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
