Question about Car Audio & Video
I am wiring a overhead dvd player model T90DVFD-BK with 3 wire harnes.I connected white, black,yellow. There is power but dome light stays on system.There is a green ground should i connect it to something.
SOURCE: Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Posted on Apr 16, 2007
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
Benimur
  • 6966 Answers
SOURCE: parking wire
To my knowledge the white/brown wire of a Dual XDVD8181 goes to the reverse lamp/switch. The pure yellow wire should go to an always on B+12 such as the battery positive terminal. It is the yellow/blue that goes to the emergency/parking brake.
Incidentally, this model is one of those that grounding the brake wire would allow DVD playback. There is a little trick to make it work. It should start first as +12 before it should be grounded before the DVD will play hence a DPST switch would be required, not only grounding.
This is better explained here. Should you be in need of the manual, it is available here.
Additionally and a friendly reminder, in some regions, it is not allowed to view a DVD movie while vehicle is in motion.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 10, 2008
  • 4102 Answers
SOURCE: wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
Posted on Apr 21, 2008
SOURCE: trying to hook up a dimmer switch it has a red
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Posted on Mar 30, 2009
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
Dome light short
... Sorry to hear about this.
Have you checked all the fuses; to see if they are good?
I would start with checking all the fuses, the dome light bulb and burnt wires. (burnt wires will smell) If you didn't smell plastic burning while hooking up the DVD player, then you're okay. But check anyway.
If you can't solve the problems, call the Toyota service department for help. They may be nice and give you some help.
Good Luck!
Apr 01, 2014 | 2004 Toyota Sequoia
Installed DVD screen and no longer have front and mid dome lights. There are 4 wires coming off player and only 3 to dome light plug. Red blue white and black on player and white/ black white/ grey and a...
There could be a feedback loop occurring, which would cause the loss of those lights. Disconnect the DVD wires 1 at a time and check for the operation of the affected lights. when the operation is restored, you may have found the culprit. Now reconnect the other wires and check again. If all works right, then that wire is the one that needs a Diode installed inline to stop the feedback and break the loop ( the Diode HAS to be installed correctly as it is a 1 way gate of sorts ) . It is also possible you may need to ground the player to a different ground. Running a wire under the dash is labor intensive, but could also solve your problem.
Good luck and thanks for using Fixya!!
Nov 09, 2013 | Car Audio & Video
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Need wiring diagram for a Pioneer stereo model AVIC-D3
Yellow - Battery
Red - Ignition
Black - Ground
Light Green - E-brake
Purples, greens, whites, and grays - speakers
Purple\white - reverse signal
Blue\white or Blue - amp turn on\ power antenna
Yellow\black - mute wire
Orange or Orange\white - illumination
Sep 03, 2010 | Pioneer AVIC-D3 Car DVD Player
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
Wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Nov 06, 2008 | Electronics - Others
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Car Audio & Video Logo
529 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
