Question about Asante FriendlyNET FS5008 (FS500820PK) 8x10/100 Mbps Networking Switch
How do I reset the Asante FS5008 switch to factory defaults ?
    Brigadier General:
  • 4,044 Answers
The rest switch is usually located on the back or bottom and will require something small like a tooth pick to press it. Sometimes it is marked reset, sometimes it is not. This can be used if you can't log into it and reset it with the menu settings.
Posted on Sep 11, 2009
How do I recover a password on a Asante IC3524?
my only suggestion is to download the latest firmware for the switch and upload it via TFTP. Once you do that it should reset the whole thing to factory default. a guide on how to use tftp for routers/switches can be found here: http://www.tftp-server.com/tftp-client.html
Jan 30, 2012 | Computers & Internet
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
Need help... is there a way to reset the switch login password?
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
Mar 14, 2010 | Linksys Cisco SLM224G Managed Ethernet...
How do you set up
Here is a page link which will help you out in configuring your Network even wireless.
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Oct 29, 2009 | Asante FriendlyNET FS4004E (99-00471-01)...
Networking
each switch need to plug into the router where they get dhcp I am assuming these are unmanaged switches
Apr 17, 2017 | Asante FriendlyNET FH10T5 (99-00418-01)...
DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Jun 20, 2008 | D-Link DES-3226L Networking Switch
Asante Talk doesn't see printer after power failure
The Asante tech support people in San Jose, CA, talked me through this fix, and I've had no further problems!
This is for system 10.5.x:
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully now.
Mar 09, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Can I reset the address of the router?
wire a computer directly with ypor router.
Have contact? if Yes you can read the IP adress within your operating software.
READ!!
Connecting two routers to each other is not difficult but is a lot more work than only changing the IP address. Firewall/ DHCP and other settings have to be changed on both routers. You need to look this up in the manuals of your routers.
Hope to have helped you.
Pascal
Jan 23, 2008 | Asante (99-00618-71) Router
Asante talk after power failure
From the manual, it suggests: 1) shut everything down 2) turn on the peripherals, let them fully start 3) For multiple computer systems, turn them on 4) Power up the Asante talk bridge.
Dec 02, 2007 | AsanteTalk - Ethernet to LocalTalk Adapter...
Lost Connection
Asante Networks, Inc. 2223 Oakland Road, San Jose, CA 95131 USA Phone 408.435.8388 · Website www.asante.com Asante Networks, Inc. 2223 Oakland Road, San Jose, CA 95131 USA · Phone 408.435.8388 · Website www.asante.com i assume you have tried to get into the router settings, if not, this is how, Make sure you typed in the address correctly. (Default: 192.168.123.254) Add http:// in front of the address. Try http://192.168.123.254:88. Make sure the link light on the front panel is on for the port you are plugged into. (If it is not, you have a bad cable, wrong type of cable, have not seated the cable well, or have a problem with your computer's ethernet adapter card.) Make sure the router is plugged in and on. Make sure your computer is set to DHCP (Mac) or Obtain IP address automatically (PC) in the Network control panel. If you can configure the router and the router can receive a proper response and IP assignment from your ISP, then you are connected to the Internet. If you are unable to browse or other such operations it is almost always because your DNS (Domain Name Server) setup is incorrect. Check both in the client computer IP setup as well as the router setup to make sure that your Domain Name Server is one that can be reached and pinged. if you need to reset the router because you've had no response, reset the router by unplugging it, waiting 10 seconds, then re-plugging it. Restart your computer. If you still are unable to get on the net, then either your isp is at fault, so check with them for a network status, or the router may be faulty.
Jun 06, 2007 | Asante FriendlyNET FR3004LC (99-00618-91)...
Asante FriendlyNET FS5008 (FS500820PK) 8x10/100 Mbps Networking Switch Logo
173 people viewed this question
Top Asante Computers & Internet Experts
David Payne
David Payne
Are you an Asante Computer and Internet Expert? Answer questions, earn points and help others
