Cub Cadet Street Sign- tractor lawn riding mower parts Logo
Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 60'' mower on a 3225 cub cadet and I need to know how the belt goes back on the mower deck. Is there a diagram online to see which way the belt goes around the pulleys.
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Sep 22, 2009
Anonymous
Master
Level 3:
Answers
389
Questions
0
Helped
273400
Points
1274
You can download an owners manual which has a pretty clear picture of the routing as well as instructions at this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/cub_cadet/hydrostatic_zeroturn_commercial_riding_mower_48546072_fabricated_deck.html
Hope this is what you need
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
1helpful
Cub Cadet 1525 belt diagram
Attached is the blade diagram for correct placement of the deck belt. There is some bleed through from the back page, but you can see the direction of the belt. I have a 1525 mower for the last 11 years, still running and going. Hope this helps! 25105582-ergctme4kokczpvvmmku3zkh-5-1.jpg
How can i get a diagram of how to change a v-belt on a cub cadet 60" recon mower
There is a site that I use frequently. Go to Partstree.com and enter your model # then look up the diagram. Usually there is a digram on the deck .
1helpful
2answers
Need to replace Deck Belt on aa Model 3225 Club Cadet . Need a diagram of how the new one goes on.
this may help Tim:
http://www.ehow.com/how_6182447_remove-mower-deck-cub-cadet.html
May 26, 2011 • Garden
5helpful
I need a belt diagram for cub cadet 3235 mower deck preferably free as this is for our church.
Type in your model number to your search engine. find your model, and your diagrams will be there.
hope this helps.
3helpful
I need a mower deck belt diagram for cub cadet 3235 54".
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
1helpful
3answers
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
