Question about Cross Pen Cross CrossPad Graphic Tablet
Cross pencil Hi, I have a 0.9mm cross pencil. The lead suppose to come out when I turn it clockwise. However, the lead would only come out about 1mm, and then it wouldn't turn anymore. The lead is also suppose to retact when I turn it counterclockwise, but it doesn't. Then, just now, the 1mm lead broke. No new 1mm lead would come out again.
I crossed spark plug wires 1994 toyota camry .Can u help me fix? 4 cylinder 2.2engine
Hi Juan !
the spark plugs wires are 4 (four) the engine works in sequence of 1342 on the distributor cap mostly writes 1 ( one ) this means the first piston-the first spark -lead. if it is there then go clockwise and put the rest following the firing order I wrote above.
Jan 25, 2015 | 1994 Toyota Camry
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
How do I change the pencil lead in an M & G MP-3290 mechanical pencil?
press the pencil lead dispensor button... (the one you press when you want more lead to protrude).
turn the exit point UP and insert new lead.
turn right side up and write away!I too love the mechanical pencils
Apr 14, 2013 | Cars & Trucks
Kenwood KM300. How to fit new mains cable ?
Having done it the hard way (!) it is dead easy. All you need is a small screwdriver or similar, approx 2mm by 1mm in cross section. Looking from outside the mixer, where the power lead enters the main body, between the rectangular lead casing and the socket it enters, there is a small rectangular cutout (top right). Push your screwdriver in around 15mm, and then withdraw the lead housing with it - the screwdriver pushes the latch aside, hence you need to remove both as one! With luck, and a wiggle or two, that should be it.
Mar 10, 2013 | Kenwood KM300 Chef Stand Mixer
Murray lawn tractor with B & S 12.5 engine seems to lock while trying to turn to start
Hi, it will be either the battery(check by jump starting with another good battery and jumper leads) or the starter solenoid(check by connecting positive jump lead directly to starter motor post. If none of this helps the valve clearances may be to wide which stops the decompressor working. Regards Phil.
Jul 03, 2012 | Garden
How to fix a cross pencil
cross revere pencil lead falls out...Mabe I am not loading. Load from top or at poing. First time repacement has been reqired
dale Taylor daleworth@gmail.com
Dec 24, 2010 | Sewing Machines
Hi i have a derbi cross city 125 back wheel problem
You can get new wheels on ebay, or at your local motorcycle dealer, and it does not have to be the exact same tyre, but it does have to be the same hight, i would reccomend bridgestone tyres as they last a hell of a lot longer than the stock, well worth your money
Aug 01, 2010 | 2008 Derbi Cross city
I have a 1970 honda trail 90, it has spark and plug gets wet when i kick it over. but it wont start!! It sometimes will make a back fire noise, when trying to start it
Remove the points cover. Make a scratch mark with a pin or nail across join of points backing plate and the outer housing and loosen two screws holding the backing plate for the point breaker just enough to rotate the plate 1mm anti-clockwise. Tighten retaining screws. Try starting now. If no joy, repeat procedure moving clockwise 1mm forward of the mark. This can be achieved with the slot end of a screwdriver between the two lugs on plate. Cheers.
Apr 28, 2010 | 1970 Honda CB 100
Karcher Dirtblaster jet does not rotate
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Apr 13, 2010 | Karcher K2.26 Electric Power Washer
Cross Pen Cross CrossPad Graphic Tablet Logo
718 people viewed this question
Top Cross Pen Computers & Internet Experts
David Payne
David Payne
Are you a Cross Pen Computer and Internet Expert? Answer questions, earn points and help others
