It just quite like it was turned off i turned it back on and i hear a click in about 3 seconds and nothing happens
    Scholar:
  • 61 Answers
Sounds like a problem in either the low or high voltage section of you TV. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
My ps3 turns on and I can hear it running, but nothing shows up on my screen. This just happened from 1 day to another. What steps should I take to try to fix it?
try holding down power button while its turning on. you will here the first beep the a second beep. release the power after second beep. the unit will revert resolution setting back to factory.
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
The fridge quit working suddenly. It defrosted totally and was hot to the touch in the back so we unpluged it. We left it unplugged for about an hour and then plugged it back in and nothing happened. It is...
the clicking sounds that you hear is the overload tripping while the compressor is trying to start but not starting. try unplugging it for a coulp of hours and please keep the door shut. let me know can you see the compressor?
Feb 20, 2011 | Refrigerators
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Receiver smoked, sizzeled and then quit
Throw on a couple of shrimp it and let us know when they're ready. You need a pro to look inside it.
Mar 19, 2010 | Yamaha RX-V2400 Receiver
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
Sony ps 3 won't show initial screen. turns on/grn light is on indicating but nothing happens/ have chgd the rca cables/ chgd tv's/made sure not dusty chgd all inputs/still no resp//any ideas? also, no...
Turn off the PS3. Press the power on button (the system will beep) and hold it down for approximately 5 seconds until you hear a second beep. This will reset the video to the default. You should get a low resolution screen and be able to log on and reset the display to the desired settings.
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
