Question about HP (ZD929AA) Computer Speakers
Have external gateway speakers
Speakers from original gateway, still have tower, yet h.p.monitor, trying to change as h.p.monitor sound stinks, has 2 cords green & flat ubs, no sound, please help, thanks. have plugged in to every port availible nothing happens, can hear the click when I turn on speakers & blue light comes on no sound
    Problem Solver:
  • 5 Answers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Posted on Sep 12, 2009
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
Have the gateway fpd2275w monitor -it has external speakers added to it.I want to get rid of them.How do I go back to original sound ?
Hello Alex,
The Gateway FPD2275w does not have built in speakers so the external ones are needed if you want to have sound. You can either have the external speakers or you can use a set of headphones.
Oct 31, 2012 | Gateway Computers & Internet
I have internal speakers on the monitor and I can't get the external speakers to work. There are no troubleshooting directions.
Try to check what type of connection you're using if its HDMI, DVI or VGA. If happens you're using HDMI it has a capability to give sound you just have to check the settings on the monitor or on the pc tower unlike the VGA and DVI you need to use speaker jack to have a sound on your monitor.
Example Pics.
HDMI connector
DVI connector
VGA connector
Hope I've helped you somehow.
AnEspera
May 08, 2011 | Computers & Internet
We have no sound on newAOC24"monitor Number2436 Gateway tower Can you help ?Technician asked for manual ,cannot find it on line Sound is supposed to be in machinebut no success by trchnician, otherwise...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 23, 2010 | Gateway Computers & Internet
Hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Jun 14, 2009 | HP w2207 Monitor
Cant get speakers on my monitor to work after I unhooked external
IF you have xp go to control panel/sound,speech and audio. You will see a drop down choice that says change speaker settings. Click on this. Then under the tab that says speaker settings hit advanced. Then select the sound scheme that says monitor with stereo speakers and apply this. Assuming you still have a functioning sound driver this should return it to the monitor speakers. Hope this helps.
Mar 29, 2009 | HP (400745-001) Sound Card
NO SOUND!
Hi
Pls check if the audio cable from the monitor is connected to the tower. Make sure it is connected to the green port at the back.
Also check the volume button on the side of the monitor and set it to maximum.
If this doesnt work, then try with another pair of external speakers and check.
Jan 22, 2008 | HP vs17
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
HP (ZD929AA) Computer Speakers Logo
95 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
